DIY Sony surround amplifier as simple amplifier - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 3rd September 2013, 11:19 PM   #1
Default DIY Sony surround amplifier as simple amplifier
Hi, I have a sony amplifier called TA-DX8
It's a sony's surround amplifier comes from a mini hifi system
(next to the right speaker)
The amplifier can only be used when it's connected to the main system through a sony cable called "SYSTEM CONTROL" It's a 13 pin connection like this
So, my question is , can i do some DIY to input sound from 3.5mm jack slots to this amplifier as my main system died
Thanks very much
Old 4th September 2013, 12:05 AM   #2
dangus is offline dangus  Canada
It looks possible. You just have to figure out what to do with the various control signals. If the main unit is sufficiently alive, maybe you can measure some voltages.
Old 4th September 2013, 12:46 AM   #3
Look online for the schematic diagram. I have the schematic for the DX80, but the connector is 13 pin.
Old 4th September 2013, 11:39 AM   #4
oops. it's the 13 pin, i had typo in the 1st post
I believe there should be some short of voltage in [protect]-[ACGround] to make the unit work. Just dont know what's the right value, others pins dont need to be cared about, right?
I would be great if you can upload the schematic diagram for DX80 so we can discuss more. thanks a lot. i'm a noob in these things
Old 5th September 2013, 03:06 AM   #5
I found the schematic on Service Manual free download,schematics,datasheets,eeprom bins,pcb,repair info for test equipment and electronics. (Search for TA-DX80)
Pin s appears to have to be high (maybe 5 to 12 volts?) to operate the speaker relay, but I suspect there will be more required.
DIY Surround Amplifier Control Center jwatts Digital Line Level 1 15th January 2013 09:03 PM
need a simple yet powerfull DIY amplifier to MJ21193G / MJ21194G power trans' WhiteRhino Solid State 5 27th July 2012 01:33 PM
surround amplifier jalejos Class D 11 7th January 2009 04:36 PM
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 16th May 2005 11:58 PM
Surround Amplifier soundNERD Chip Amps 19 1st August 2004 03:46 AM
Copyright 1999-2017 diyAudio
