RFI and speaker cables? - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 17th August 2013, 10:04 PM   #11
Pano is offline Pano  United States
Pano's Avatar
Originally Posted by JonSnell Electronic View Post
I can't think of an amplifier with RFI in the loudspeaker connections.
I'm listening to one right now! I own several others.
(Class-D)
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 17th August 2013, 10:12 PM   #12
jcx is offline jcx  United States
from next door in an apartment building power line conducted noise is possible too - mains filtering may help
Old 18th August 2013, 02:46 AM   #13
brig001 is online now brig001  United Kingdom
Yes, you are right and a friend has just pointed out that it's likely to be the lift (elevator), so just going to filter everything.
Thanks,
Brian
Old 18th August 2013, 10:35 PM   #14
Lavcat is offline Lavcat  United States
Lavcat's Avatar
I once had a problem with RFI from the other side. My six meter transmissions were causing interference to someone's hi-fi. Never did solve it.
These days my speaker cables run near AC cords, computers, and SCR's but I don't have any interference problems that I know of. (There was a shortwave station in my phono stage that turned out to be caused by a Monster interconnect.)
Would there be audible benefit to adding ferrites all over everything? I'm sure there is a lot of RFI floating around here. But I don't think I can hear or taste or smell it.
I became a believer in ferrites when a company I worked for had to add ferrites on our products' cables to meet FCC certification.
Old 18th August 2013, 11:10 PM   #15
Pano's Avatar
Because RF was coming out the cables?
Old 18th August 2013, 11:43 PM   #16
Send a message via AIM to DigitalJunkie
I used to have a neighbor with a boosted-up CB radio. I'd be rudely awoken by his trucker voice blasting from my speakers every morning. (even if the stereo was off.) Ferrite,small bypass caps,shielded cables,different amps,more grounds,nothing fixed it. Luckily I wasn't the only one he annoyed,cause a couple weeks later they were gone,I suspect evicted.
I like the clip-on ferrite beads,and tend to use them a lot.Great for power cords,and other various cables. They're handy RFI stoppers,I at least kinda try to quench RFI/EMI,if I can.
(Trying to listen to a shortwave radio/scanner with a PC nearby is a mess of whistles,and 'ghost carriers',for example.)
Old 19th August 2013, 09:56 PM   #17
Lavcat's Avatar
Yes.
Old 19th August 2013, 10:03 PM   #18
Lavcat's Avatar
One can be punished for that, at least in the US. The FCC would propose a non-technical solution.
Old 19th August 2013, 11:29 PM   #19
Neville Thiele (of T/S fame) designed a LCR network for the output of a power amp' which, when connected to a speaker of appropriate impedance, increases amp' stability and also acts as an RFI filter for noise picked up by the speaker leads. I will try and describe it. Assume 8 ohms. There is a parallel LR network of 2mH and 8ohm in series with the output. Then instead of the classic 8R and small cap' in series from the hot (speaker end of the LC network) to the ground he just has a small cap'. About 0.1uF I recall. Looks odd but when the speaker is connected (i.e. across the cap') it forms an parallel RC network and all things being equal the amp then "sees" an 8 ohm resistance and any RFI picked up by the leads experiences a 6db/oct attenuation before getting to the output terminals.
The first version used on some local DIY magazine kits from the mid '70s was the basic version which gave a 6db/octave roll off. But if you chase up the JAES paper there are two further iterations of 2nd and 3rd order networks (more complicated and elegant) for very severe cases of interference. Can't think of the actual year and volume reference right now.............
actually it is; JAES 1976 24(1) pp 20-23.
Jonathan
"It was the Springtime of the year when aunt is calling to aunt like mastodons bellowing across primeval swamps." P.G. Wodehouse.
Last edited by Jonathan Bright; 19th August 2013 at 11:38 PM. Reason: Found the reference
Old 24th August 2013, 12:27 PM   #20
Magz is offline Magz  United States
I've found from experience that adding ferrites to a signal line is not to my tastes; it always seems to change the sound in a direction I don't like.
I did however, DIY some RC speaker cable filters that are still in place. Once installed at both the amp and speaker end of the wire they seemed to me to have a very positive effect on the sound. Whether they are filtering out RF or simply terminating the TL more effectively, I don't know, but they do something I like. I calculated the characteristic impedance of the speaker wires at RF and chose the resistor value to match that. The caps are cascaded silver micas. Before potting I embedded the caps in mortite to attempt to damp resonances. Inside the potting box is an inner box of TI-shield material.
Here are a few pics showing what I did. The final filters are potted in epoxy and as hard as bricks.
speaker cables dave k Multi-Way 13 10th June 2016 04:55 PM
Gotham interconnect cables, speaker cables and coaxial cable Musik007 Twin Audio 24 23rd August 2013 04:57 PM
Your Speaker Cables... jleaman Multi-Way 41 17th May 2006 02:29 AM
cables for diy amps, preamps, and speaker cables ... paulspencer Solid State 5 3rd August 2004 07:14 AM
Copyright 1999-2017 diyAudio
