What effect (If any),
Does fitting a GOSS band around the iron circuit of a standard mains Tx have?
Ie not around the windings, over the iron circuit.
A clamp mount is just steel over the iron circuit and it is linked from end to end with the chassis.
So a GOSS band over the iron circuit is similar?
M. Gregg
M. Gregg
That's what this site calls it,
G.O.S.S. Band - Custom Designed Toroidal Transformers from Nuvotem Talema
Normally fitted around toroid transformers.
What effect does it have around the iron circuit of a standard E/I core?
M. Gregg
M. Gregg
