wi fi extender diy antenna - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 26th July 2013, 06:58 AM   #1
protos is offline protos  Greece
protos's Avatar
Default wi fi extender diy antenna
Sorry not audio related but thought some of you guys would know.
I have a wi fi extender with four on pcb internal antennas
But the signal I am getting from the free WiFi area beach is marginal. I am thinking of making a diy yagi antenna to boost the signal by about 10db but do I connect it to any internal antenna on the pcb?
``The author always assumes that when power is applied , the amplifier will explode or ,at the very least, catch fire.
Morgan Jones, Building Valve Amplifiers.
Old 26th July 2013, 11:05 AM   #2
DUG is online now DUG  Canada
Unless you can tap into a point that matches the 50 ohm coax feeding your antenna, you may loose more signal than your antenna can get you due to impedance mismatch.
Best are the units with detachable antennae...that you can work with.
There are many articles about "coffee can antennae" for wifi on the net and some of them may address the impedance mismatch issue.
Have fun.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 26th July 2013, 05:15 PM   #3
protos's Avatar
Hmm good point. I guess the impedance match is with a capacitor?
Old 26th July 2013, 05:33 PM   #4
I am having trouble visualizing what you have and
want to do with it. Could you post a picture.
Old 26th July 2013, 10:13 PM   #5
At these frequencies anything with length can be an inductor and anything with area can be a capacitor.
And your impedance matching may require a couple of each.
I don't even consider trying this modification an option.
If you had a unit with a detachable antenna...
Old 26th July 2013, 11:31 PM   #6
I use one of these, after reading many good reviews....
Alfa AWUS036H Upgraded to 1000mW 1W 802.11b/g High Gain USB Wireless Long-Rang WiFi network Adapter with 5dBi Antenna - for Wardriving & Range Extension: Amazon.co.uk: Computers & Accessories
I have a DIY cantenna which is directional, and a +9db omni antenna.
It's only b+g but this is rarely an issue if you're trying to connect to free public wifi.
I'm sure this would work well with a yagi. I got best results using no rf cable and directly connecting the unit to the cantenna using a coax termination adapter (can't remember the exact type). A long USB cable (with active extender if required) is less of an issue than a lossy coax.
If you search google you can find out how to increase the tx power beyond normal levels. It's a simple process, although you might accidentally exceed legal limits in your region. I obviously haven't done that, but believe the benefits can be significant.
Please show us your solution when you've finished the project.
Old 27th July 2013, 06:55 PM   #7
protos's Avatar
This is the PCB . As u can see there are two little add on PCB with squiggly antennas and behind them are two PCB antennas one of which is a metal plate and the other is just a track on the PCB.
Old 27th July 2013, 08:29 PM   #8
pilli is offline pilli  France
I've had good success with a parabolic reflector screen, although it won't work easily with the device in your picture.
The parabolic thing is much easier to build than a cantenna or a yagi. Probably much less effective, but it literally takes 20 minutes to give it a try: all you need is some paper where you print the proper pattern and some aluminum foil. Search on internet for "parabolic wifi reflector".
But the antenna must be in the focus point, not easy to do in your setup.
Old 27th July 2013, 10:49 PM   #9
protos's Avatar
A yagi diy is very easy just a piece of 1 meter 1 cm2 wood and a meter of copper wire is needed.
The question is will it work if I attach it to the existing antenna network and where.
Old 28th July 2013, 05:08 AM   #10
yagi design online:
Online Calculator .:. Yagi Uda Antenna
(not really so simple)
The other thing about Rf (besides the "anything with length can be an inductor and anything with area can be a capacitor") is that with inductance and capacitance come a characteristic impedance.
And if the characteristic impedance is not utilized correctly you can end up with an RF short circuit at a point that can measure open circuit with an ohmmeter.
The Circuit Designer had to match the impedance of the antennae to the transmitting and receiving devices. There might not be a point where the impedance matching networks transformed to a point where you can tap in with a 50ohm (or other) load.
You might not affect the circuit at all. Which is OK for the circuit but you will not be extracting any power to transmit with.
Or you may detune the existing circuit to either present a higher impedance load to the transmitting device and not get any power for transmitting or present a lower impedance and blow up the transmitting device.
Just sayin.
FS: KINDLE W/3G AND WI-FI drptpcpe Swap Meet 0 26th February 2012 04:07 PM
Copyright 1999-2017 diyAudio
