Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
What is a formula for magnetic conductivity
Old 18th July 2013, 12:47 AM   #1
srinath is offline srinath  United States
Default What is a formula for magnetic conductivity
I am looking for magnetic conductivity table or formula.
My question is this ...
If I took a lets say N50 magnet and stuck it to a steel plate 1/4" thick, what would the rating be on the other side of the plate.
Will it be more for say steel and less for cast iron, etc etc.
I know it will be more than 1/4 of air ? How much more ?
Cool.
Srinath.
Old 18th July 2013, 01:46 PM   #2
DF96 is offline DF96  England
'Magnetic conductivity'? You might get some help by googling 'magnetic flux calculations'. Bear in mind that calculation is only tractable for situations with simple geometry and useful symmetry - everywhere else you need to do a field-level simulation.
'Rating'? Do you mean field strength?
Old 18th July 2013, 02:10 PM   #3
Let me try that ...
See I have a carver planar magnetic tweeter I took apart.
The thing has magnets that are 10mm X 10mm and about 150mm long. They are magnetised through the thickness, so the magnetic pole is 10mm X 150mm. It is no stronger than n8. Cos its alnico or ceramic. So N5 or N8.
My idea is to put a Neodymium magnetic base of 10mm X 3mm X 100 mm strips and then a 6mm steel bar on top. Neodymium is available from n25 all the way to n52.
I want about N8 @ the top of the steel strip.
What is the strength of neo I need as the base. That is where this question is based on. I'll check what I find.
Thanks.
Srinath.
What is a formula for magnetic conductivityHide this!Advertise here!
Conductivity of materials and interconnects dfidler Everything Else 26 28th June 2011 11:15 PM
Conductivity bridge argonrepublic Equipment & Tools 2 11th December 2009 10:30 PM
Thermal Conductivity of Kapton Compared To Aluminum? kelticwizard Everything Else 7 20th June 2007 05:23 AM
crossover conductivity problem REALFLEO Parts 16 3rd January 2007 05:15 AM
conductivity of hot glue? Dominick22 Chip Amps 4 20th June 2006 04:18 AM
