Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Eq'ing tracks with nero waveditor
Old 2nd July 2013, 09:45 AM   #1
ctrlx is offline ctrlx  United Kingdom
Default Eq'ing tracks with nero waveditor
I'm adding some bass to tracks, around 3-6db. It sounds fine when i am in the processing of doing it, but once i save it, its sounds different. The new bass level is ok but the snare drum hits have lost the level/impact??
Old 2nd July 2013, 06:50 PM   #2
Zero D is offline Zero D  United Kingdom
Hi, 2 things i'd point out.
1 - With in SPL increase, have you clipped the audio ?
2 - Because of the extra bass, the overall tonal balance has changed.
Old 3rd July 2013, 08:37 AM   #3
Before EQ, i reduced the volume by -6dB to allow for the EQ.
The tonal balance is ok in the preview mode (with EQ), but once the file is saved then it changes.
Old 3rd July 2013, 04:22 PM   #4
What type of file is it, & being saved as ? 2 seperate things !
Try this FourierRocks. A WAV file comparison tool | Free Audio & Video software downloads at SourceForge.net
Old 3rd July 2013, 05:04 PM   #5
sofaspud is offline sofaspud  United States
sofaspud's Avatar
Good questions asked by Zero D. The above statement suggests a bug in the software; the preview should be just that, otherwise it's not very useful.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 4th July 2013, 07:39 AM   #6
16bit wave in and out.
I will try out some other software to see if i get similar results.
Eq'ing tracks with nero waveditorHide this!Advertise here!
TAD TM-1201h EQ'ing virious Multi-Way 9 18th May 2016 11:29 AM
Tracks for demo'ing new PA equipment gshep Music 5 5th November 2012 05:04 PM
EQ'ing out the VUVUZELA from world cup matches? col Everything Else 4 16th June 2010 02:43 PM
Eq'ing midbass horns / your thoughts ? RobWells Multi-Way 0 21st November 2006 10:41 PM
Noticed that Nero ULTRA 7 Support 192KHz Audio alvaius Digital Source 0 21st January 2006 05:03 PM
