Formatting an external hard drive - some help wanted - Page 3 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 26th June 2013, 01:32 PM   #21
kevinkr's Avatar
I don't use compression, unless you intend to stick to windows and have a very fast processor I find it more trouble than it is worth. I use a mix of linux and windows machines here and like the fact that linux has no trouble reading or writing to conventional NTFS formatted drives.
Ashok, we all have those moments..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 26th June 2013, 06:56 PM   #22
hpeter is offline hpeter  Slovakia
hpeter's Avatar
using rar or zip archives has a benefit, (if i forget the less used space) then sure it is the repair feature.
you must enable it before compression, though (1...xx%)
ntfs can reduce filesize, with built in filesystem compression, no external program needed. Such files have blue names
BLOG. XMOS_U8/PCM5102A > LL1544A > 6H1Pi+µfoll > 2A3_SOV/JJ > LL1660 > STAX SR207 _ SR L300 _ SR007 # LL2748 > 394A > LCLC 4H/100µ
Old 27th June 2013, 05:14 AM   #23
KMossman's Avatar
Send a message via Yahoo to KMossman Send a message via Skype™ to KMossman
Originally Posted by ashok View Post
KMossman: Thanks for the advice. I actually did that but didn't use any compression. I guess I should be doing that too.
Compression usually does little for video and images, so best to use no compression if most files are such.
Maybe you needed to select ALL directories and sub-directories to make it work on your zip/rar/etc utility.
Getting back into business, though non-audio related. Have excellent contacts for NEW [OEM] Russian and Chinese tubes. Custom chassis, and parts [MOQ applies]
Old 27th June 2013, 05:21 AM   #24
KMossman's Avatar
all depends on your priority - minimizing space or minimizing time!
Most compression utilities allow the user to select the degree of compression; usually more compression means more time and less space.
The type of file influences the degree of compression - some image and video files may even be larger after compression. Like any tool, knowing it well makes a big difference in the effectiveness.
What is the difference between a solid state hard drive and a regular hard drive? Sebastianebilly Everything Else 12 19th February 2013 01:49 PM
upgrade power supply for external hard drive ? kevinr PC Based 3 21st November 2011 01:36 AM
Audiophile hard drive jamesfeline PC Based 34 14th November 2011 01:42 PM
Wanted: External, portable CD-ROM or DVD drive; decent USB DAC, portable speakers. Spasticteapot Swap Meet 0 31st May 2006 02:13 AM
Dead hard drive Dennis Hui The Lounge 2 28th August 2004 08:03 PM
Copyright ©1999-2017 diyAudio
