Why does my booxbox not save my radio presets? - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 3rd June 2013, 07:51 PM   #1
Default Why does my booxbox not save my radio presets?
I have a JVC boombox and it seems to work fine except for the fact that it does not save the radio presets when it is turned off. I think it used to save the presets just fine, but now when I turn the radio off and on, the presets are no longer there. The radio does stay plugged into the electrical outlet in the wall while it is off though. I would appreciate some advice on how to fix this problem.
Thank You
Old 3rd June 2013, 08:04 PM   #2
chris661's Avatar
It might be worth seeing if there's a little watch battery in there that's died - such things are often used in computers to keep the time, so I'd expect similar usage here.
Old 3rd June 2013, 08:22 PM   #3
Speakerholic
Cal Weldon's Avatar
But that's for when the unit is unplugged. I am guessing something has gone wrong.
planet10 needs your help:
Let's help Ruth and Dave
Old 3rd June 2013, 08:27 PM   #4
KatieandDad's Avatar
Some of them use a SuperCap. Try looking for a 1F 5V or similarly huge value cap.
Old 3rd June 2013, 10:11 PM   #5
may be a bad cap as katieandDad posted, also look at the resistors and diodes. The resistor is for the charging of the cap, and the diode allows current flow in 1 direction.
Old 3rd June 2013, 11:01 PM   #6
Enzo is offline Enzo  United States
But isn't that his problem? When power is removed it forgets everything. Certainly that is the first place to look: dead memory battery. We see that in pro audio all the time. SYnthesizers usually have patches in memory that can be edited by the user. Lose the battery and the memory resets to factory or turns to gibberish.
The unit either has a battery backed memory, or some sort of flash memory. And yes, a super cap could be used in place of a battery in many places.
Old 4th June 2013, 10:01 AM   #7
I have come across a tuner that lost its settings due to a small serial EEPROM failing
Old 4th June 2013, 10:25 AM   #8
FoMoCo is offline FoMoCo  United States
I'd put my money on this. Either that or the EEPROM is built into the micro and has failed from too many writes.
Account Deletion Requested: 1/26/2014
Old 4th June 2013, 12:53 PM   #9
Speakerholic
Cal Weldon's Avatar
Not according to the OP. This is while it is plugged in.
Old 4th June 2013, 01:37 PM   #10
If the SuperCap has failed it might just drag down the EEPROM memory.
Marantz SR4120 not holding station presets Burnedfingers Solid State 5 23rd November 2011 05:17 PM
UK Residents - Petition to save FM radio!!! Telemin Everything Else 18 19th July 2010 12:06 AM
Clarion 2 yellow wires = no presets memory?? metaverse Car Audio 1 15th January 2009 08:30 PM
Aleph-x help me save it. anders.a Pass Labs 47 13th July 2006 06:46 AM
Onkyo TX866 Presets lincolns6 Solid State 0 31st December 2005 01:08 PM
Copyright 1999-2017 diyAudio
