Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Fancy Interconnects?  How about a potato, or even mud?
Old 3rd June 2013, 03:14 AM   #181
Pano is offline Pano  United States
Pano's Avatar
I did some testing this afternoon thru 6 feet of tap water, salt water, diet Coke, wine and coffee. The beer - I drank.
Conclusions:
  • Tap water: Very bad, almost no signal
  • Very salty water: OK. About 6dB attenuation and some noise.
  • Diet Coke: Had to boil it to release the carbonation, otherwise it was just fizz. Terrible conductor, heavy attenuation.
  • Wine: A little better than Coke, but not much.
  • Coffee (black): Similar to wine.
Don't try to make liquid cables, unless it's mercury. The things I tried make awful conductors. Maybe over a few inches, like the banana, they would be OK - but not over 6 feet.
I'll get some files up pronto.
Take the Speaker Voltage Test!
Old 3rd June 2013, 03:37 AM   #182
fas42 is offline fas42  Australia
Banned
Just tried an interesting exercise of more vigorously comparing the FLAC versions of the track, which I hadn't done as yet now knowing the results -- which for my setup points out there are 3 factors at play: the variations in the recorded tracks, the impact of mp3 encoding, and the relatively cheap and nasty quality of my playback hardware. These are very roughly of similar levels of impact in degrading the sound, making it a more obtuse exercise to pick rankings.
By only playing FLAC, the mp3 bits are discarded; and now the easily discernable last place is D, the mud version - this has nothing to do with the glitch, the cymbals are clearly rendered more poorly. But the others are harder, and this is due to junk connections and components of the PC speakers; reseating the plug, and refreshing the volume pot setting makes as much difference as switching between versions. To get an authorative assessment would require taking the quality of the playback mechanism largely out of the equation, by transferring all tracks to a significantly higher quality system ..
This is where blind testing can get into trouble -- are you hearing the real underlying differences, or are the inadequacies of the testing environment masking these qualities ...?
Old 3rd June 2013, 03:42 AM   #183
Pano's Avatar
Once you know what is what, it's not a blind test. You don't like D because you know what it is. I'll randomize those files again in the FLAC version and let you listen.
But don't worry, you'll have no trouble picking out the awful wine and coffee recordings.
Old 3rd June 2013, 03:50 AM   #184
Pano's Avatar
Default The goofy set up
Here are photos of my goofy test rig - just so that you can see what I'm doing. It's not pretty, but science rarely is.
The test leads are some unknown mic cable with 2 conductors and shield. The two conductors are tied together into 1, the shield is connected only at the sound card.
Sound card is the M-Audio Fast-Track Pro USB running at 44.1KHz, 16 bit. Player software was Foobar 2000, recording done with Audacity. Editing done with Goldwave. Computer is an HP netbook with Atom processor, Windows 7.
Old 3rd June 2013, 03:57 AM   #185
Banned
I don't get fussed about the blindness, what disturbs me is that the quality literally alters as you listen, call it 'memory distortion' of the system if you want - I've been doing this type of critical listening for decades. If what you're listening to is of sufficiently high quality then this effect is relatively low level, you don't notice it happening - depending upon everything, the quality change can go up or down over a period of time - speaker drivers typically steadily improve as they warm up, say.
Knowing how good something is supposed to be doesn't do for me, the amount of crap sound I've listened to from 'good gear' over the years is a total turnoff ...
Old 3rd June 2013, 04:13 AM   #186
sakellogg is offline sakellogg  United States
sakellogg's Avatar
I wonder if the coil of fluid has diffrent inductance? Not that it matters for your test just got my weels turning.
I'm not crazy, my mother had me tested
Old 3rd June 2013, 04:15 AM   #187
On Hiatus
SY's Avatar
Keep dancing, Frank.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 3rd June 2013, 04:28 AM   #188
Banned
Trollin', trollin', trollin', keep them ...
Old 3rd June 2013, 04:48 AM   #189
Banned
I feel I've got a decent handle on separating the FLAC versions now: the DAC is reasonably well conditioned after a couple of hours running, and I needed a section of the track where the quality issues of the playback can be overridden. So, using Audacity on repeat for the section from about 17.5 to 20.5 secs makes it quite straightforward, it's a good conjunction of a peak of the voice, drums and piano, where one can compare the clarity of each element in the presence of the others.
Old 3rd June 2013, 05:44 AM   #190
Pano's Avatar
Default New clip order
OK, here are the same files again, but the mud is gone replaced by steel wool.
EDIT: I had some glitches. Will fix and upload again. Sorry.
Fancy Interconnects?  How about a potato, or even mud?Hide this!Advertise here!
Potato 74G14 vs Fairchild 74VHC14 KlipschKid Digital Line Level 21 24th February 2013 04:22 PM
You say potato, I say potaato. You say FE126E, I say FE126EN brucegseidner Full Range 6 28th November 2010 05:22 AM
JBL 175 Drivers w/ Potato Masher 1217-1290 Horns/Lenses djfitz Swap Meet 0 18th March 2009 04:52 AM
Big pond of MUD! rx7speed Subwoofers 6 24th January 2008 04:05 AM
Gainclone-the sound of one channel clapping/Happy as a pig in mud Dr.H Chip Amps 10 13th August 2003 01:04 AM
