Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 3rd December 2003, 06:26 AM   #1
Send a message via AIM to zx3chris
Default Plumbing help
ok diy gods -- i need some help --
long story short -- i hae a leak in the ceiling -- found it by cutting some holes. galvanied pipe to copper, massive corrosing -- leak. Piping here is very old, no shutoff valve for that line, so therefore i have no water in the entire house and no heat -- cold night..
Whats the best fix here -- replace the galvanied pipe entirely and resolder a new copper connection? I am not experienced with plumbing but i think this is simple enough for me to take on. I have a butane torch, and a rotozip saw to cut pipe.
here are some pix
close up1
close up 2 -- how does the copper hooked up to the gal pipe? i know it is gal to reducer to copper - but does the copper solder or is it screw in as well?
tia guys
-chris
Old 3rd December 2003, 06:42 AM   #2
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
well you may have no water. But prince Rupert island in Canada B.C has no gas the entire island is with out natural gas because of a land slide just out side of town witch has knocked off all gas to the rupert area : O(
HAHAHAH glad i don't live there any more...
Old 3rd December 2003, 07:55 AM   #3
Netlist is offline Netlist  Belgium
Netlist's Avatar
If you don't have the right tools to fix this I suggest you try with plastic pipes and connectors. Cut out the bad pieces and replace with above mentioned.
Something like this: http://www.islandwaterworld.com/pdf/137.pdf
/Hugo
Old 3rd December 2003, 01:09 PM   #4
Schaef is offline Schaef  United States
Default Plumbing in an audio group???
Okay, a couple of things here. First, where does the galvanized go? Is it the main feed to the house or is it an end point that connects to something in the house?
If its an end-point, then I'd say replace the entire galvanized run with copper (or plastic, your choice) If its the main feed to the house, then I'd say call a plumber and have them do the work. (hate to say it, but that's the way I'd approach it)
As to the galvanized to copper connection, if its done right, there are connectors for this that work to reduce the problem you're seeing. It will solder onto the copper and be a screw on, onto the galvanized pipe. Translation, if you're looking to just replace the joint, you'll need some way to cut new threads on the galvanized pipe. (not cheap)
Personally, I'd look at replacing the entire run of galvanized with copper, you'll more than likely find that the galvanized is almost completely blocked with gunk inside.
Old 3rd December 2003, 02:03 PM   #5
JOE DIRT®'s Avatar
cheap route:
1. cut back the galv. pipe a foot back and buy a brass sweat coupling....you will need silver solder or sylfoss to braze on the the Galv. pipe
make sure place a valve on to isolate the rest of the system because you will have to drain it
2. expensive route: tear the Galv. pipe right out and replace with copper
The Galv. pipe will have so much crud in it that you will probably want to go this route.
DIRT®
Old 3rd December 2003, 02:08 PM   #6
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Take this picture to Home Depot and they will advise you what you need. Make some measurements of the pipe sizes as well.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 3rd December 2003, 02:11 PM   #7
sully is offline sully  United States
Account Disabled
I believe you are having the problem because of galvanic corrosion..
Call in a plumber..you have code issues as well as long term corrosion issues to contend with..
Sometimes, the right person for the job is another person..I would not undertake that project myself, even though I do a lot of diy plumbing..
Cheers, good luck...John
Old 3rd December 2003, 04:17 PM   #8
thanks guys, from the advice here and other forums i am going to replace the entire length of the pipe with copper - and use a dieletric union this time -- this is what caused the corrosion last time.. the help from forums is the best, thanks ;D
-chris
Old 4th December 2003, 12:19 AM   #9
while i was doing this research my parents called a plumber -- he came and wanted $780 to fix it! so they turned to me and i went to home depot, spent $13 on parts and fixed it in 3 hrs -- thanks for the help guys
-chris
Old 4th December 2003, 02:03 AM   #10
li_gangyi's Avatar
crazy plumber...$780?? I could redo the almost the whole house with that...haha....but seriously did he really ask for 780 just for that section or for more??
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Plumbing speakers purplepeople Full Range 44 5th January 2005 04:54 PM
Page generated in 0.17240 seconds (53.14% PHP - 46.86% MySQL) with 10 queries
