Current Mirror Explanation Needed. - Page 3 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 7th July 2012, 07:50 PM   #21
jan.didden's Avatar
But the resistor is not connected to ground....
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 7th July 2012, 07:55 PM   #22
tsiros is offline tsiros  Greece
tsiros's Avatar
Send a message via MSN to tsiros Send a message via Skype™ to tsiros
through the transistor, of course. not sure how much current will go around and through the base, i'd hazard a guess it would be very little, negligible maybe
is the transistor operating in saturation now?
Old 7th July 2012, 08:00 PM   #23
tsiros's Avatar
does that imply that the Ie=β*Ib not only works right-to-left, but the transistor will try to balance Ie and Ib to satisfy that equation in other cases too?
Old 7th July 2012, 08:01 PM   #24
jan.didden's Avatar
Ahh yes, but we know EXACTLY how much goes where. We know that the base current is 1/beta of the collector current. Or, vice versa, Ic = beta* Ib. Assume beta = 100, then Ib = (1/100)*14.4mA and Ic = (99/100)*14.4mA.
Now we connect the second transistor, base to base, emitter to gnd. It has the same Vbe, so the same Ib, so the same Ic...
So whatever you hang off that 2nd collector, the 2nd transistor will try to pull the same Ic through it - there's your current mirror!
jan
Old 7th July 2012, 08:05 PM   #25
jan.didden's Avatar
I don't think a transistor has any concept of left or right - it just 'sees' what's connected to its three terminals. It cannot work different than the way it is supposed to.
I don't think so. The Vce is equal to Vbe which is 0.6V. I think the definition of saturation is that Vbc is only a few 10's of mV. But others may know that better.
jan
Old 7th July 2012, 08:09 PM   #26
jan.didden's Avatar
A final one now: suppose I connect the 2nd collector of that mirror to the same +15V through a 500 ohms resistor, what is the Vce of the 2nd transistor?
jan
Old 7th July 2012, 08:14 PM   #27
tsiros's Avatar
yes, well... i have two objections. you can ignore them if you deem them inappropriate or just moronic. I need to study more...
it can operate differently (depending on how you define "operate", i might be getting a bit boring or infuriating, please don't ban me) if it gets damaged...
second, and this is my main point, i do not know if i am conveying my thoughts properly:
i know if you stick a Ib, it will try to draw the appropriate Ie, but does the transistor try to balance the equation even if you stick a Ie and let Ib be variable?
maybe i have taken the "water valve" parallel a bit too seriously... because a valve sets the water flow, but the water flow can't set the valve position, which the transistor can.
jan
okay. still, you and the rest of the gang have been of great help.
Old 7th July 2012, 08:17 PM   #28
tsiros's Avatar
jan
Ic = 14.4 mA,
Vce = 15 V - 14.4 mA * .5e3 Ω = 7.8 V ?
Old 7th July 2012, 08:23 PM   #29
jan.didden's Avatar
Perfect! Of course, if you're picky you may want to take account of the small differences caused by the 1/100 of Ic that goes through the base, but I never do that. It's close enough as it is.
Old 7th July 2012, 08:29 PM   #30
jan.didden's Avatar
[snip]i know if you stick a Ib, it will try to draw the appropriate Ie, but does the transistor try to balance the equation even if you stick a Ie and let Ib be variable?
Well whatever you 'stick' as Ie needs an Ib to flow, right? For instance, if you ground the base and pull the emitter negative, the emittor will become negative until Vbe becomes 0.6V, then Ie will start to flow. In fact, Ie will increase so much that the current will develop enough voltage across whatever is pulling it negative so that the emitter will not drop any further. You can break the transistor that way, or it can go into heavy saturation, but the behaviour is exactly predictable by the way a transistor 'normally' works.
Now as you hinted, if the transistor gets into saturation, the nice Ic/Ib=beta breaks down. For instance, if you send 1A into the base there's no way that Ic becomes 100A (unless you have a really big one). But for 'normal' use the beta-concept works pretty well.
jan
QTS/OB explanation needed InclinedPlane Full Range 36 19th May 2010 04:30 AM
Current Mirror: The V-mirror rtarbell Solid State 1 19th November 2008 02:27 PM
no current mirror, current mirror, cascoded current mirror, bjt or jfet VAS? maxpou Solid State 31 17th June 2008 04:31 PM
Current mirror abzug Solid State 7 1st January 2008 07:03 PM
AC power connection schematic explanation needed Peter Daniel Pass Labs 20 31st July 2007 04:16 PM
Copyright 1999-2017 diyAudio
