Current Mirror Explanation Needed. - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 7th July 2012, 06:17 PM   #11
tsiros is offline tsiros  Greece
tsiros's Avatar
Send a message via MSN to tsiros Send a message via Skype™ to tsiros
well, the current flowing into the p doped semi between the n doped semi, controls the flow of current, i'd rather not get into the QM behind it, but i never thought it can work in reverse?
how can i impose a current?
this can't work with only one transistor, right? not the current mirror, the appearance of a voltage at the base when forcing a current through C/E
Old 7th July 2012, 06:51 PM   #12
DF96 is offline DF96  England
The voltage appears at the base because it is connected to the collector. A BJT is not a superconductor, so if a current flows it will cause a voltage drop. The voltage drop is across both base-emitter and collector-emitter as they are connected together.
You appear to be thinking about a BJT in current terms. As I said, you will never understand current mirrors (or many other BJT circuits) if you think in this way. Think in terms of applying a voltage to base-emitter.
Imposing a current is easy (approximately). You just need a battery and a resistor. If the resistor is the dominant resistance in the circuit then you have (approximate) control of the current. Remember, Ohm's Law says nothing about causality: does voltage cause current or current cause voltage?
Old 7th July 2012, 07:09 PM   #13
jan.didden's Avatar
Originally Posted by tsiros View Post
well, the current flowing into the p doped semi between the n doped semi, controls the flow of current, i'd rather not get into the QM behind it, but i never thought it can work in reverse?[snip]
If you have a transistor, B connected to C, the E grounded and the C/B through 1k to +15V, what do you think will happen?
jan
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 12 is out! Check out my Autoranger and SilentSwitcher
Old 7th July 2012, 07:18 PM   #14
tsiros's Avatar
i will experiment and see how it goes
thank you all for your patience, effort and time!
Old 7th July 2012, 07:20 PM   #15
jan.didden's Avatar
What will be the voltage across the 1k you think?
jan
Old 7th July 2012, 08:05 PM   #16
tsiros's Avatar
15 V minus the Vbc drop?
Old 7th July 2012, 08:24 PM   #17
jan.didden's Avatar
No, B is connected to C, remember? So Vbc = 0...
But you're close. You really must draw it, then it's clear. Remember, pencil and paper ;-)
Old 7th July 2012, 08:26 PM   #18
tsiros's Avatar
npn, right?
15 V minus the Vbe drop, usually 0.6 V
edit: i really should stop relying on mental images for things with which i haven't got much experience :/
Old 7th July 2012, 08:32 PM   #19
jan.didden's Avatar
You're doing fine. So we have +15V on one side and Vbe (0.6V) on the other side. Ohms law says there will be 14.4mA through that 1k.
Where does that go?
Old 7th July 2012, 08:36 PM   #20
tsiros's Avatar
doesn't have anywhere else to go, to ground.
is the transistor operating in saturation right now?
QTS/OB explanation needed InclinedPlane Full Range 36 19th May 2010 05:30 AM
Current Mirror: The V-mirror rtarbell Solid State 1 19th November 2008 03:27 PM
no current mirror, current mirror, cascoded current mirror, bjt or jfet VAS? maxpou Solid State 31 17th June 2008 05:31 PM
Current mirror abzug Solid State 7 1st January 2008 08:03 PM
AC power connection schematic explanation needed Peter Daniel Pass Labs 20 31st July 2007 05:16 PM
Copyright 1999-2017 diyAudio
