Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Current Mirror Explanation Needed.
Old 7th July 2012, 08:29 PM   #31
tsiros is offline tsiros  Greece
tsiros's Avatar
Send a message via MSN to tsiros Current Mirror Explanation Needed.
you're not supposed to know β accurately, anyway... just that it's some large number... at least that's what i've learned from horowitz&hill
it will take some reading (and drawing) to make sure i 'get' what you typed last
again, many thanks.
Old 7th July 2012, 08:38 PM   #32
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally Posted by tsiros View Post
you're not supposed to know β accurately, anyway... just that it's some large number... at least that's what i've learned from horowitz&hill.
Exactly. Not only does the beta vary between transistors, even the same type, but the Vbe necessary for a specific current also varies.
If you read some of the earlier posts, someone mentioned using smallish (10-100) ohms emitter resistors in both mirror transistors. The resistors provide negative feedback and that will tend to cancel out beta- and Vbe differences.
How does that work? Suppose the 2nd transistor has more beta than the first one. That would give it more Ic than the first one and the 'mirror' is no longer 1:1. But the larger Ic (and Ie) also means that there is more voltage generated across that 2nd transistor Re. That extra voltage can only mean that the Vbe gets a bit smaller, which decreases the Ic/Ie. So it works to diminish the effect of any beta differences (and similarly any Vbe mismatches).
jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 7th July 2012, 08:54 PM   #33
cbdb is offline cbdb  Canada
It might help to start with the simpler diode transistor CCS, get a handle on it, then return to the transistor wired as a diode. The operation of the two is identical (except in matching).
Old 7th July 2012, 08:57 PM   #34
tsiros's Avatar
so the current mirror is stiff in β and Vbe(Ie) variations...
hey do me a favour? post your interview with Nelson Pass somewhere, the link from your blog is going nowhere
Current Mirror Explanation Needed.Hide this!Advertise here!
QTS/OB explanation needed InclinedPlane Full Range 36 19th May 2010 04:30 AM
Current Mirror: The V-mirror rtarbell Solid State 1 19th November 2008 02:27 PM
no current mirror, current mirror, cascoded current mirror, bjt or jfet VAS? maxpou Solid State 31 17th June 2008 04:31 PM
Current mirror abzug Solid State 7 1st January 2008 07:03 PM
AC power connection schematic explanation needed Peter Daniel Pass Labs 20 31st July 2007 04:16 PM
