Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
I'd like to improve my electronics skills....any suggestions??
Old 8th April 2013, 05:46 PM   #11
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
There are some good videoes on youtube about soldering through hole and SMD.
I had some trouble with SMPS soic8 ic. I kept blowing it up soldering it in.
In the end I found I needed a temperature controlled iron just warm enough to melt the solder and some liquid flux to help things flow a bit better.
I found it just about impossible to remove ic's with an iron so bought a hot air gun.
PCBCAD51 pcb design software. 2018 version out now. http://www.murtonpikesystems.co.uk
Old 9th April 2013, 02:38 PM   #12
bear is offline bear
expert in tautology
bear's Avatar
Consider NOT working on stuff you care about.
In fact it might make sense to buy a known junker amp, tube or solid state, and repairing or rebuilding it into something else.
I second "The Art of Electronics" by Horowitz and Hill, the writing is very very easy to follow. Probably the best written electronics book in history.
If you do tubes then you want a copy of the 4th edition of Radiotron Designer's Handbook. It's available as a download pdf too, on Pete Millet's great site (along with a ton of other classic reference books).
So, the way to do this is to work on something that you can afford to have fry and blow up... you NEED a 'scope, a DVM, and a signal generator (or other suitable source of sine and squarwaves). The scope's calibrator signal will be ok for square wave. You can buy a $30 DSS module on epay that does all sorts of frequencies and other tricks now. A bright light over the bench... the 'scope is essential. No scope? Can't really work on audio gear.
_-_-
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
I'd like to improve my electronics skills....any suggestions??Hide this!Advertise here!
Suggestions for upgrading to electronics in this Mic(M Audio Luna) OMEGA757 Parts 0 22nd August 2012 06:36 AM
Anyone heard of MDL Electronics Capacitors? .. thinking I may need to improve? Deaf Cat Multi-Way 12 20th February 2012 10:16 PM
Need suggestions for electric guitar electronics project xander Construction Tips 1 29th January 2010 08:47 AM
Ideas, suggestions, and schem to improve Sony sdpep9 es? mpmarino Digital Source 9 19th September 2008 06:21 PM
Any suggestions on setting up a dedicated electronics work area at home ? Ohighway Equipment & Tools 24 17th September 2008 12:41 AM
Copyright ©1999-2017 diyAudio
