Tube or solid state? - Page 3 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
View Poll Results: Solid state or tube?
Solid State 12 50.00%
Tube 12 50.00%
Voters: 24. You may not vote on this poll
Old 29th March 2013, 05:56 AM   #21
hpeter is offline hpeter  Slovakia
hpeter's Avatar
Originally Posted by nigelwright7557 View Post
You can use a soft limiter to emulate a valve sound at a much better price.
i guess at low-medium levels it will still not make sound like real tube amp
BLOG. XMOS_U8/PCM5102A > LL1544A > 6H1Pi+µfoll > 2A3_SOV/JJ > LL1660 > STAX SR207 STAX SR007 # LL2748 > 394A > LCLC 4H/100µ
Old 30th March 2013, 03:32 PM   #22
namesmeanlittle's Avatar
ok this i have to comment on
each has there place
tubes sound better i can give 50 reasons why
but if you build one they have to tuned and set with channels for hours because the heat changes them and you only get a ruff best place
most are tuned at higher temps so as it runs longer it gets the best sound
they are delicate drop one brakes, move a hot one brakes
most HAVE to have low to no feedback 8 ohms (main stream) + today, was 16 ohms
vary power hungry like a tank just eats to go vary little
pain to build, not for faint of hearted
heats room up
but sounds so good
tubes burn out
cost $$$$$$
can have big amp built in vary small box
solid state
cheaper
easy to build
can drop slam beat the amp will not brake transistor
low ohms capability
can operate a big systems and afford electric bill... better anyway
can be made BIG easy
simpler
does not sound half as cool
bigger amp power=bigger amp size
hybrid
tube preamp
transiter driver
sounds better than solid state closest to true tube amps
has solid state output ease, can make big outputs easy
the better of both without the major flaws
its personal choice
and monitory ability
the radio in my pic is tube
it makes the coolest sound
but for half an hour its out of tune every 5 mins as it heats up
still love it
sometimes a 49 general electric am radio is just down right cooler than the 100+ watts of sound around
Old 14th April 2013, 12:09 PM   #23
horses for courses. Big power,use solid state.Personal listening,use tubes they keep you warm and rock and roll.
Solid state tube? carpenter Solid State 26 17th August 2009 09:37 PM
solid state Vs Tube Rectification sandy Tubes / Valves 3 3rd September 2004 04:20 AM
Best Tube 4 Solid State Jay Tubes / Valves 17 29th March 2003 04:08 PM
solid state or tube? jaybird Solid State 5 1st February 2003 10:17 AM
tube/solid state hybrid Kilowatt Tubes / Valves 11 20th January 2002 11:17 PM
Copyright ©1999-2017 diyAudio
