Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 6th December 2003, 04:53 PM   #31
Magura is offline Magura  Denmark
Magura's Avatar
whats the difference between anodizing and alodine???
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 15th October 2004, 11:29 AM   #32
Banned
Anodizing is an electrochemical process that changes the chemistry of the aluminum, in such as way as to make a very hard surface. It creates an oxide layer that is pretty tough.
IOW......scratch resistant, etc.
Alodine is a simpler operation that just puts a nice finish on aluminum, but can easily be scratched.
Alodine is basically a dip. Anodising requires electrolysis.
Typical application:
Front panel: anodise. It has to be able to withstand handling and abuse.
Metal parts inside unit: alodine. Shiny enough, but will not withstand scratches. Mostly to prevent oxidation of the surface.
Jocko
Old 15th October 2004, 03:20 PM   #33
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
The difference between anodizing and alodine could be compared to treating wood with hard lacquer or using sealer.
Alodine has effect of the sealer. It penetrates surface of aluminum, but does not create any protective surface like anodizing. That's why it is not a protection against scratches at all.
What I find appealing though is the simplicity of applying. Just dipping for few seconds is enough, and to me, it sometimes creates nicer finish than anodizing.
I usually brush it off a bit with scotch brite pads, after applying, and this removes any goldish shine. The aluminum looks more like stainless steel and is completely resistant to stains when handling. As long as you take enough care not to scratch it, it is a cheaper alternative to anodizing.
This panel was treated with alodine:
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 15th October 2004, 03:34 PM   #34
Pbassred's Avatar
Send a message via MSN to Pbassred
Paint
Jeeees! I only asked
www.davethebass.com
Old 18th October 2004, 12:08 PM   #35
Default bigger plate...a suggestion
take a bigger plate (bigger than required) do the finishing/brushing first and then cut it to size. this will get rid of the problems at the edges. Needless to say; cutting job should be perfect.
something to finish mdf paulfk Multi-Way 14 14th March 2009 03:04 PM
To paint brushed aluminum Duo Everything Else 23 9th October 2007 05:22 AM
Mark Kelly DC Brushed Motor Controller circuit pjpoes Analogue Source 2 1st February 2007 11:05 AM
How to finish brushed aluminium? bm_mode Everything Else 3 21st September 2002 02:55 PM
Brushed aluminium Vivek Everything Else 4 18th July 2002 07:20 PM
Page generated in 0.08167 seconds (72.64% PHP - 27.36% MySQL) with 11 queries
