| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#21 | |
Ohh Peter...please dont do that...i guess we all like you here...and if you keep on using paint thinner while using your belt sander...we suddenly wont have you around for a while. An electrical motor makes sparks, and a belt gets static....more sparks. I have seen it blow up in the face of a guy using a powerdrill...not a nice sight. How were your experiences with anodising at home?? easy?? cheap?? deadly poisonous?? Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#22 |
I started using Varsol after the recommendation from a commercial place that do metal finishing.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#23 |
I dont know what VARSOL is, but i sure hope its not flameable like paint thinner.
I usually use petroleum(kerosene) it works well, is easy to clean of and is almost impossible to ignite.......and it isnt paticulary poisonous (unlike paint thinner, wich is not for home use, since the fumes are very toxic). Magura
#24 |
#25 |
Point taken
I just got vorried that youd blow up Magura
#26 |
Have you looked at the MSDS for Varsol? Not very nice stuff to come in contact with. Any solution to this? I would think even latex-type gloves would be even more dangerous than the varsol.
#27 |
Accept the fact that your hands will eventually fall off if using kerosene or varsol....but you got a nice looking amp
Magura
#28 |
Peter, just take it to a shop that does grain sanding and alodine coating....There is an art to grain sanding and worth the minimums involved in graining and coating......My shop has a $25 minimum......Don't care for alodine coating as either bright silver or gold as I recall.....Like it either black or clear anodize.....
Bob Crump |
#29 | |
The plates had to be redone, anodising had to be stripped, brushed again and anodised again. It all took additional time, so now, when doing prototypes and small runs, I prefer to do finishing myself. The good part is that I can have it all done in one sfternoon, without waiting a week or two for metal finishers. You know how it is, when only chassis keeps you from listening to your next creation.BTW, I think I mastered the art of grain sanding pretty well ![]() The minimum they charge here is $75 -100 CAD. Of course if it's 20 pcs or more, I'm not trying to do it myself.
#30 |
I have had some trouble as well with finishing, but finally found a good shop to do the grain sanding and anodize work. I still have to run all over the place with knobs as have to be bead blasted, have lines engraved in them, then anodized and then paint filled......Three different shops involved......The grain sanding/anodize shop have $25 minimums, the bead blasting is $15 and engraver wants $50 minimum.....Runs about $300 to have our two chassis 60 pound preamp chassis finished and engraved.....Found a guy with a pantograph machine who does nice engraving and normally have it engraved through the anodize with the black anodized units. No set-up involved so each unit can be touch different as respects the lettering....`
Bob Crump |
| something to finish mdf | paulfk | Multi-Way | 14 | 14th March 2009 03:04 PM |
| To paint brushed aluminum | Duo | Everything Else | 23 | 9th October 2007 05:22 AM |
| Mark Kelly DC Brushed Motor Controller circuit | pjpoes | Analogue Source | 2 | 1st February 2007 11:05 AM |
| How to finish brushed aluminium? | bm_mode | Everything Else | 3 | 21st September 2002 02:55 PM |
| Brushed aluminium | Vivek | Everything Else | 4 | 18th July 2002 07:20 PM |
| Page generated in 0.11495 seconds (81.73% PHP - 18.27% MySQL) with 11 queries |
