Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Adapt 14 pins into 8 pins
Old 25th February 2013, 07:30 PM   #1
Liliya is offline Liliya  Norway
Default Adapt 14 pins into 8 pins
I want to replace the IC TBA231 with OPA2134. TBA 231 is mounted in a 14 pins holder, while OPA 2134 stop at 8. Does there exist a adapter that convert from 14 to 8 pins?? If so, where can I get in?
Other good suggestions will be received with thanks.
Eivind Stillingen
Old 25th February 2013, 07:33 PM   #2
Rundmaus is offline Rundmaus  Germany
Rundmaus's Avatar
Difficult to talk about an adapter without giving the datasheets or at least the pinouts of the two ICs.
With one being 8pin and the other 14pin, I would doubt they are made to do the same job without more circuit modifications.
Greetings,
Andreas
Old 25th February 2013, 08:55 PM   #3
AudioLapDance is offline AudioLapDance  Canada
I'm just Mr. Cut-n-Paste these days ... I learned how to use Paint!
TBA231:
TBA231.pdf
It will depend on how your circuit uses pins 2, 3, 4, and 10, 11, 12 of the TBA231.
This probably won't be an easy swap ...
Old 25th February 2013, 09:09 PM   #4
Rundmaus's Avatar
Apart from the compatibility issue, one of those socket whatevers, a piece of perfboard and a plain 8pin socket would do...
Andreas
Old 25th February 2013, 09:30 PM   #5
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Eivind Stillingen
1) why?
2) what do you expect to achieve?
3) post the schematic where you intend to replace it
4) in a nutshell, you can not pull a TBA231 and plug a different one in there, even if you had a proper "pin rerouting" socket .
Old 25th February 2013, 11:17 PM   #6
Back in the 70's I built a Sentec SE77 preamplifier (Swedish). This was one of my very first DIY projects. Since then, there have been many more. This preamplifier had as many others, to give way to new and more interesting projects later on, and has since been stored in my garage. As part of a larger “clearing projects” in older DIY projects, I brushed the dust of this preamplifier. To update SE77, I have been inspired by this: http://www.svalander.se/tips_fakta/h...iering_sentec/
Sorry that this is only written in Swedish, which is a easy thing for us Norwegians to understand.
I have, after I asked my question on this site, sat down for to maybe find a workable solution. See attached photo where I have made a "test" on a veroboard and with a NE555.
Since there is no more modern subsitutes for a 14 pin TDA231, I want to go for OPA 2134
Comments are welcome.
Old 26th February 2013, 09:12 AM   #7
Rundmaus's Avatar
To be honest, the 'test' looks a bit crude to me
I think I wouldn't solder directly to the pins of the replacement opamp, but use a socket for it instead. Use a 14pin socket adapter as shown above, reroute the needed pins on a small piece of veroboard and put a 7pin socket adapter on it for the new chip.
More difficult, but probably will look nicer and work more reliable in the end.
Andreas
Old 27th February 2013, 08:08 AM   #8
A better solution was found: I took away the 14 pins IC holder. Blank wires to OPA 2134 from both sides of SE77 PCB. More "elegant" then my first attempt.
This works very, well and with a much better sound then TDA 231.
Eivind Stillingen
Adapt 14 pins into 8 pinsHide this!Advertise here!
Which pins to use first? brucetassin Tubes / Valves 6 16th July 2012 07:10 AM
Why that many DECOU pins? roibm Digital Source 14 6th December 2005 09:54 PM
why multi pins ? 6SN7GT Tubes / Valves 9 10th July 2004 01:46 PM
crystal with three pins.. Marlowe Digital Source 4 16th January 2004 03:50 PM
lm pins theChris Chip Amps 0 26th April 2003 10:32 PM
Copyright ©1999-2017 diyAudio
