Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Condenser Microphone Circuit Help!
Old 18th February 2013, 11:54 PM   #1
Danny9j1 is offline Danny9j1  United Kingdom
Default Condenser Microphone Circuit Help!
Im new to electronics but I'm keen to learn more and get involved with building my own equipment. I understand the basics of how each electronic component works and want to apply this knowledge to something i Use regularly. I have started taking apart a cardiod large diaphragm condenser microphone. Again I know how the basics of how the microphone works but am unsure of what the different circuits between the Capsule and the output are. I would really appreciate it if someone could point me in the right direction. Thank you.
Images of the microphone circuits are (or should be attached).
Old 19th February 2013, 03:43 AM   #2
DUG is offline DUG  Canada
.jpg seem to be easier to work with.
I have found.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 19th February 2013, 03:53 AM   #3
dchisholm is offline dchisholm  United States
dchisholm's Avatar
Your question may get better response in the Yahoo "micbuilders" group at micbuilders : micbuilders
Dale
Old 19th February 2013, 01:01 PM   #4
Thank you both for the response ill definitely have a look at the mic idlers group. Ad ill try and upload some jpegs.
Dan.
Old 21st February 2013, 07:55 PM   #5
Am I right in saying one of the circuits is a preamp and the other deals with the incoming 48volt phantom power? I realise with the two switches for Low cut and -10b theres more circuitry there but I would just like to know the basics of what would be needed to allow the microphone to function correctly without any additional features.
Old 27th February 2013, 09:50 PM   #6
Ron E is offline Ron E  United States
Ron E's Avatar
Do a search for 'condenser microphone preamp phantom power' and sort through the results. You'll probably want to check what capsule you have to find out if it is an electret or not and how many wires connect to it, etc...
There are standard circuits for 48V phantom power. You might want to define your problem more as I am not entirely sure what your goal is.
edit - here's a nice article:
http://www.thatcorp.com/datashts/AES...ic_Preamps.pdf
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 27th February 2013, 10:57 PM   #7
benb is offline benb  United States
What brand and model mic is this? There's a reasonable chance there's a schematic of it somewhere online.
"Preamp" isn't quite the right word for the circuitry that connects to the capsule - maybe "buffer amp" would be better. If it's a non-electret condenser element, it needs an external FET to buffer the very-high-impedance signal from the capsule, and that would be on one of the circuit boards. Otherwise, electret mic elements usually have a FET built in that does this.
Regardless, it's hard to know offhand what each circuit board does, or the function of everything in the whole circuit without a full schematic diagram.
That's a neat article, but it describes the preamp on the other end of a phantom powered balanced mic cable.
There's a schematic and I think short description of a (non-electret) condenser mic in the book "The Art of Electronics" second edition.
There's also this forum where they build mics and other studio equipment: http://groupdiy.com
Old 28th February 2013, 12:04 AM   #8
Thank you for your replays its help clear a few things up and the article on the preamp was definitely worth a read so thanks for the link the microphone pictured isn't an electret microphone it's a cheap large diaphragm condenser ( t- bone sc450 not USB ) it has a cardioid pickup Pattern only and has a switches for a -10db pad and another to activate a high pass filter. I've tried looking for an exact schematic but can't find one so figure I'd try for something more popular like the NT 1 a. The aim is just to find out the barebones of what the circuit is that is allowing the capsule to function propyl as a microphone. I have a capsule bases on an m7 microphone capsule which I'm I'm then hoping to add to a circuit and create a basic functioning microphone. The only problem I've had is that I didn't realise how many different ways there was of doing it.
Condenser Microphone Circuit Help!Hide this!Advertise here!
Tube condenser microphone help! btown2009 Tubes / Valves 67 12th November 2013 03:54 AM
condenser microphone question jonslaten Analog Line Level 9 13th November 2010 07:24 AM
Condenser microphone repair argonrepublic Instruments and Amps 2 13th January 2010 12:15 AM
Help with circuit for condenser microphone capsule ? mwmitchell Solid State 6 28th July 2003 03:46 PM
