| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I've got this APC 300va ups lying arround. I'm woundering if it would be easy to rebuild the UPS to a battery PSU?
I need 12-0-12 for a project and it has a 12v 7.4 mah (i believe) battery. |
#2 |
I also still have such an APC thing lying around.
Thought about the same but: You could basically leave in the charger and the battery and youŽre done. But this will leave you with a basic 12V PS which wonŽt get you far. YouŽd need another battery and another charger. But one battery is a start isnŽt it? Cheers Jens |
#3 |
you can rip out the bat...but can you send me the inverter part?? Lolx...
Kids in the back seat cause accidents...Accidents in the back seat cause kids... |
#4 |
Why would I need a second battery?
Does this mean I can't make +12 0 and -12 out of 1 battery? Before reading what the LM7912 does exactly I thought I could use one to invert polarity. At the moment I'm a bit lost, I don't see how I can make +12 into -12? |
#5 |
you could use a SMPSU chip in inverting mode to get -12V...but it wouldn't work well in your case as you are drawing a large current and typically it's also not suited for "audiophiles" because of the switching noise that it makes...you cannot use a 7912 to get -12V...it has to be connected to another battery...and by the way...the 7912 must have a higher voltage for it to regulate properly...and if you are gonna use it for an amp...I believe the 1A current capacity that it has is insufficient...
| Battery Charger for 15V Li-ION Battery Pack ??? | Jan Dupont | Parts | 2 | 11th April 2009 02:18 PM |
| KEF - rebuild into OB ? | poynton | Multi-Way | 1 | 16th August 2007 08:09 AM |
| Help with amp rebuild | zeke | Tubes / Valves | 15 | 4th October 2004 01:39 AM |
| rebuild | offroadbum | Multi-Way | 2 | 25th February 2004 04:11 AM |
| HFT-90 anyone rebuild one before? | ajhawkins | Tubes / Valves | 10 | 12th July 2003 05:38 PM |
| Page generated in 0.08524 seconds (69.35% PHP - 30.65% MySQL) with 10 queries |
