Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
240V mains measuring and sampling.
Old 30th January 2013, 09:09 PM   #11
martin clark is offline martin clark  Europe
Tektronix publish a nice short guide - 'Fundamentals of Floating Measurements and Isolated Input Oscilloscopes'. (copy/paste that into google...)
NB Tek DO NOT recommend using a mains isolation transformer to 'float' a scope, ever.
Meanwhile that's an elegant technique, Elvee. I've only used small toroids but found with the sig gen that with a nominal loading - say 1K across the secondary - regular smallish mains step-down toroids can be quite good enough to present a flat passband beyond at least ~30Khz to a soundcard. More than enough for what I was interested in, and cheap to try.
Edit to add - last toroids I measured had under 500pF stray C pri:sec (650VA 35-0-35VAC in my power amps, actually). That's the real reason for a nominal secondary load on top of any two-resistor potential divider to set your signal input level.
Old 31st January 2013, 01:23 PM   #12
costasx is offline costasx  United Kingdom
Thank you all for your help and prompt replies.
@sim0n #2:
Yes, probe's ground is connected to chassis GND.
I think I can't use the scope to measure the mains voltage directly because the RCD will trip due to the internal connection chassis GND to mains earth. TT or TN system, must look at it.
My intention was to use a 240/240 isolation transformer to power the oscilloscope so that it 'floats', thus permitting me to connect scope's chassis GND to Neutral and the probe to Live. Of course EXTREME care is mandatory when dealing with mains voltages.
The same isolation transformer could be used to power the desktop PC. Then a 100:1 resistive attenuator will bring the 240VAC within soundcard's range. I feel that a laptop running off its batteries could also be used and no transformer is required.
sim0n and DF96: I think the transformer will filter out some of the components that corrupt the mains power. My intention is to expose and record the contamination of mains power.
@DF96 #3: very clever the idea of a resistor to load the secondary in order to avoid saturation. I had forgotten that, thanks.
@AndrewT #4: Yes, to investigate the components of mains power.
@Elvee #9: indeed, transformers can do a lot of things. I had read somewhere that transformers can be used as power conditioners, up to a point ofc.
EDIT_1: @ martin clark #11, the .pdf is invaluable, thank you.
Old 31st January 2013, 01:46 PM   #13
sim0n is offline sim0n  Slovenia
The input impedance of scopes (typically 1Megaoogm) isn't high enough to trip the RCD (typically 30mA @ 240V -> 8000ohms trips it)
Also, if you're going to be monitoring this all day do you need the exact trace of each individual disturbance or are you just interested in the frequency of how often they occur (i.e. every event is bad anyway)
Old 31st January 2013, 02:31 PM   #14
sim0n,
Right, the input impedance of the scope is >1MOhm. It's doubtful whether the oscilloscope allows the user to disconnect the mains earth from the probe GND. I will look at it anyway. Perhaps some other scope has a switch that connects/disconnects the mains earth to chassis.
The soundcard will do the monitoring and the recording, I will use the oscilloscope occasionally to take pictures of the disturbances. (if I am around and one occurs)
Old 31st January 2013, 02:56 PM   #15
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
I would use a battery powered, floating, 3000V Opto Isolated "sensor head" to sample line voltage/waveform/whatever and then use standard stuff on "this side" of the barrier.
Which by the way is the way Pros do it.
I'd never never never ever connect any scope probe to any live wire.
Not even neutral !!!
Ground is fine , of course.
Old 31st January 2013, 04:38 PM   #16
DF96 is offline DF96  England
Any stuff which doesn't make it past a toroidal transformer is unlikely to affect any electronics, so should not be of any interest.
Messing about with mains is dangerous, so safety always must take precedence over accuracy/bandwidth/convenience etc.
Old 31st January 2013, 06:05 PM   #17
JMFahey's Avatar
Yes, that's a practical approach.
You could use any regular, say, 220:12V transformer, resistively load its secondary to put magnetizing current and low level hysteresis out of the way (or to be more precise, to make conditions more realistic) and measure that.
It will be an accurate sample of what happens at the primary side.
Old 31st January 2013, 06:52 PM   #18
Elvee is offline Elvee  Belgium
Elvee's Avatar
Resistive loading won't change anything to magnetizing current or hysteresis.
It could slightly alter the magnetizing current if it is unduly heavy, but anyway the magnetizing current per se is not a problem, the saturation is.
On the other hand, loading will significantly degrade the reproduction of harmonics. It will also slightly magnify the effect of hysteresis.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
240V mains measuring and sampling.Hide this!Advertise here!
PC Down-sampling / Up-sampling / Asiodrivers / Asynchronous streaming Explained BIA Software Tools 0 1st July 2012 01:06 PM
Wanted: Leak ST-50 Mains transformer 240V yairf Swap Meet 1 17th March 2011 01:44 PM
Measuring from UK schematic but on US mains patrickamory Tubes / Valves 4 28th August 2007 04:54 AM
Simple method for 240V from 240V line eeyore Tubes / Valves 10 14th June 2007 10:42 PM
Toroid or EE Ferrite core, which is Best for 240V mains SMPS Workhorse Power Supplies 49 6th February 2007 06:44 PM
