Soundwave theory question: reflection - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 16th January 2013, 05:22 AM   #1
tnargs is online now tnargs  Australia
Default Soundwave theory question: reflection
Hi, is anyone able to help me grasp a particular question please.
If a 300mm (1 foot) diameter column is pressed up against the front of a loudspeaker (or just clear) ----
1--- which wavelengths reflect straight back to the speaker?
2--- which wavelengths are scattered widely?
3--- which wavelengths are relatively unaffected and pass right around the column?
4--- is there a transition region between 2 and 3 and if so, what happens in it?
I would like to better understand the relationship between deflector size and sound wave behaviour.
Thank you
Old 16th January 2013, 05:55 AM   #2
How big is the driver?
There is open source software to model this at
AcouSTO - Acoustics Simulation TOol - Homepage
but not easy to use
Old 16th January 2013, 12:22 PM   #3
Well it is an in-principle question, so I will take any driver size you care to assume. thanks
Old 16th January 2013, 12:23 PM   #4
I haven't seen that tool before. I will take a look.
Any generalised answers would also be much appreciated.
Old 16th January 2013, 07:54 PM   #5
Ron E is offline Ron E  United States
Ron E's Avatar
I think you will find that this is much easier to measure than calculate, and it depends on your observation point. Probably the best way to resolve this qualitatively is with a java ripple simulation calculator - do a search.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 16th January 2013, 08:10 PM   #6
Thanks Ron, I'll have a look.
I wonder if there is a general rule like "if the wavelength is more than twice the column diameter, there is little to no scatter of the sound"?
Old 16th January 2013, 11:42 PM   #7
The behaviour of a plane wave passing your column is fairly easy to predict. You have a far more complex situation as the column is close to the source and gives early reflection back to the driver
Old 18th January 2013, 11:27 PM   #8
Ron E's Avatar
It's probably closer to 6 times...
Old 19th January 2013, 04:14 AM   #9
Thanks Ron and David, I will continue to study it.
Old 19th January 2013, 11:59 PM   #10
chris661's Avatar
Would a Hornresp simulation throw out anything useful?
Electronics Theory question... stereo.pete Everything Else 5 15th April 2009 03:03 PM
Question on the theory/practice of 2/3/4...-way speakers JCDenton Multi-Way 3 6th June 2006 07:13 AM
question of theory cominup Multi-Way 3 7th May 2004 05:28 AM
Question on L-pad theory/formula leadbelly Multi-Way 8 19th January 2004 06:39 PM
Basic loudspeaker theory question Andrej Multi-Way 6 28th April 2002 07:53 AM
Copyright 1999-2017 diyAudio
