| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#31 | |
Of the three I like Geoff's proposal the best if you can afford the 4 bridge rectifiers. |
#32 |
Paul
The utilisation factor for a transformer/rectifier circuit (defined as the ratio of the dc output power to the transformer rating required by the primary and/or secondary) is 0.572 for a full-wave centre-tapped circuit and 0.812 for a bridge rectifier circuit. This means that either a smaller transformer can be used with a bridge rectifier or, for a given VA rating, more dc output power is available. The foregoing figures apply to rectifier circuits providing a single polarity output (as was being done in blmn's circuit). When a centre-tapped arrangement is used to provide dual supply rails, the utilisation factor increases to that of the bridge rectifier. Geoff |
#33 |
Subwo1,
If the transformers were perfect you would be right, but filtering needs are defined by load, transformer regulation and frequency. Since the transformers and the load are defined (JoeBob's case), for the same transformer, for a given VA rating, as Geoff said, you have more power available and, if I don't miss something here, better regulation (less core losses, less wire losses etc). regards |
#34 |
I can see how Geoffs diagram works, and 2 more 35A bridges doesn't cost more (it's just 50A and above are ALOT more expensive for some strange reason). And if ti's the most efficient way I think I'll go that way. The PSU box is almost done so I'll wire it up tomorrow.
And Geoff, you're correct, two windings, not center tapped... |
#35 |
Warp Engineer
On Holiday
Yeah, I agree with Geoff. His design probable contains the least number of potholes so i'd got with that.
#36 |
Geoff,
Do you have figures on efficiency as well? Utilization (oops I mean utilisation) you've defined as power out / VA rating required, but I think this might be different because of the pulsating nature of the current draw. What would the actual losses in the transformer be for the two cases? My thinking is that by utilizing less power from the transformer it keeps its internal heating down. I normally like to run a transformer well under its VA rating. Anyway, it's a moot point: JoeBob has the cash for the extra rectifiers; we all agree it's the best approach. Go for it, JoeBob! Paul |
#37 |
The title of this post was 'Simple Bridge Rectifier Question'. Well, it wasn't so simple after all, was it? :-)
Geoff |
#38 |
Paul
Your last post came in whilst I was composing my previous comment. I agree with you about oversizing transformers, or putting it your way 'running them well under their VA rating'. I normally recommend a VA rating of 5 times the the amplifier rms power (in watts) for Class-A amps. Class-AB can be somewhat less. I was quoting the Motorola (now ONSemi) 'Power Supply Design Manual', an essential read, though many other sources make the same point. The figures are calculated from the relationship between the rms and average current and so take into account the pulsating nature of the current draw. You ask if I have figures for efficiency as well. How are you defining this if it isn't 'power in to power out' i.e. the utilisation factor? Geoff |
#39 |
Hi Geoff,
Yes, I was enjoying the irony of this thread's title as well. I asked because power is not the same as VA. I'm curious as to what happens with the "extra" VA capability. I know that with a power factor other than unity, amperage is wasted in "imaginary power" that doesn't actually appear at the load; I'm wondering whether the extra VA capability required for a fullwave CT (for the same load) actually results in extra heat in the transformer - i.e. losses. Just rambling, I haven't actually thought this through any further. I really do enjoy these discussions, there are a lot of very knowledgable people here and I always come away from these learning something new. Thanks for the reference on the ONsemi manual, I may pick up a copy. Paul |
#40 |
blmn,
Actually it does make sense that there would be a difference. I could see loading the same winding for a whole cycle instead of a half cycle could help utilize core flux and keep the windings more compact.
| Bridge rectifier voltage question | woody | Power Supplies | 1 | 1st May 2008 01:47 AM |
| bridge rectifier question | crippledchicken | Power Supplies | 31 | 25th April 2008 12:17 PM |
| Bridge Rectifier question | hotscot | Power Supplies | 14 | 15th January 2006 05:15 PM |
| Bridge Rectifier Question | sam9 | Solid State | 3 | 16th October 2004 02:03 AM |
| Page generated in 0.10715 seconds (87.91% PHP - 12.09% MySQL) with 11 queries |
