Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 13th February 2002, 07:20 PM   #11
JoeBob is offline JoeBob  Canada
JoeBob's Avatar
Well, I've only got 2 caps and two transformers. And if I wanted to use multple power suplies less power would go to some channels then others, which I'd rather avoid. I'll just try using a bridge for the positive and one for the negative and see how it goes. When only using either the positive or the negative poles of the bridge, the opposite pole is sent to ground, correct?
Old 13th February 2002, 07:29 PM   #12
paulb is offline paulb  Canada
JoeBob, could you let us know what your transformer voltages are and what DC voltage you expect to get? I'm a bit confused. The arrangement you mentioned doesn't use the centre-tap of the transformer, but I was talking about using it as ground. Your way will get twice the DC voltage.
Old 13th February 2002, 08:06 PM   #13
arnach is offline arnach  United States
Send a message via AIM to arnach
Default Hello
People seem to be saying that it's ok..
If you pull 30A amps out of a 35A bridge recitfier it will BURN UP. I've seen it happen many times.
Also, why don't you at least spec a 50A amp part or use individual diodes? Using individual 60A diodes you'd be fine..
-- Aaron
Old 13th February 2002, 09:23 PM   #14
blmn is offline blmn  Brazil
blmn's Avatar
Arnach,
If you use correct sized heatsink the bridge will not blow up considering 85% of their continuous nominal capacity. I had some in my bench power supplies with this problem when I was testing some class B amps. I solved it increasing the heatsink. However, there are some manufacturers wich use peak, or not continuous, current value information for their devices as a basic information, and, in these these devices have much less continuous current capacity.
regards
Old 14th February 2002, 02:17 AM   #15
JoeBob's Avatar
Well, I checked and the peak for my bridge is alot higher then 35A, in the hundreds, although I can't remember exactly what.
paulb, sorry, I don't really understand how you mean to connect it. Each transformer is a 750VA +/- 24VAC toroidal with dual primaries and dual secondaries. The DC voltage I'm gathering I'd get is probably around 28VDC or 30VDC, it doesn't really matter exactly, it's for some LM3886's. I hope that clarifies some things, sorry for my ignorance by the way, I just don't see how I can use one transformer for the + and one for the -, if using them the center-tapped way, wouldn't that produce twice the DC voltage, compared to using them in parallel?
Old 14th February 2002, 02:32 AM   #16
Warp Engineer
On Holiday
AudioFreak's Avatar
Joebob,
i'd wire the primaries as per your mains voltage then wire the same secondaries of each transformer together and use 2 bridges to form the rails .... the + of 1 bridge goes 2 +ve rail, -ve goes to gnd, +ve of other bridge goes to gnd, -ve of same bridge goes to -ve rail.....
i'll post a pick of how this looks later if you want. you've just got to make sure all the AC phasing is correct.
Old 14th February 2002, 03:32 AM   #17
blmn's Avatar
JoeBob,
Maybe something like this was the idea of PaulB. Don't worry about the polarities of the transformers.
regards
Old 14th February 2002, 03:34 AM   #18
blmn's Avatar
OOOPS, the capacitor at the negative side is inverted. Sorry...
Old 14th February 2002, 04:05 AM   #19
JoeBob's Avatar
Oh, now I understand. Thanks, I'll give that a shot. Thanks for all the help guys.
Old 14th February 2002, 04:21 AM   #20
Warp Engineer
On Holiday
AudioFreak's Avatar
or you could try this.......
Bridge rectifier voltage question woody Power Supplies 1 1st May 2008 01:47 AM
bridge rectifier question crippledchicken Power Supplies 31 25th April 2008 12:17 PM
Bridge Rectifier question hotscot Power Supplies 14 15th January 2006 05:15 PM
Bridge Rectifier Question sam9 Solid State 3 16th October 2004 02:03 AM
Page generated in 0.11557 seconds (80.26% PHP - 19.74% MySQL) with 11 queries
