| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Hi, I'm building a cabinet for my home theatre setup using Polk audio db series car speakers i had lying around, will it hurt to use them on a 6ohm receiver?
The receiver is 125rms @ 6ohm the speakers are 88spl and 100rms @ 4ohm they dip to 3.4ohm at low freq. They should be easier to drive then cheap 6ohm speakers. If I'm totally wrong please advise. Thanks, Was |
#2 |
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Supposing that the amplifier inside the receiver is a normal one, you can use 4 ohms speaker in a 6 ohms output stage, bat keep in mind that power output, temperature inside the cabinet and distortion will all them being increased. There would not be any trouble using them. But, in any case, use less volume control set.
LW1DSE |
#3 |
Cheers I suspected as much but wanted to clarify as everyone's opinion seems to be different on the matter.
| 4ohm 6ohm 8ohm.... My home | Shido151 | Full Range | 1 | 15th June 2012 02:54 PM |
| Edcor XSE (4ohm), GSXE (6ohm) | wushuliu | Swap Meet | 1 | 14th February 2012 12:35 AM |
| Using 6ohm speakers with Audiolab 8000a MK1 | bonapardo | Solid State | 3 | 15th December 2010 05:43 PM |
| Need a good amp for a pair of 4ohm, 40w nominal fullrange speakers | zinblade19 | Chip Amps | 10 | 29th March 2009 05:33 PM |
