Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 14th November 2003, 10:57 PM   #1
Steve Eddy's Avatar
Default The more things change...
The patent claim reads:
This invention relates to improvements in low loss cables and has for a main object the provision of a cable formed of a plurality of conductors contacting each other at points and spaced apart from each other between said points, there being less surface area of conductors in contact at said points than the surfaces out of contact with each other between said points.
Another object of the invention is the provision of a conductor somewhat of the "Litz" type, comprised of a plurality of insulated conductors assembled into a cable with portions of their areas in contact and portions of their areas in non-contact relation with the other conductors, the areas of said non-contacting portions being far in excess of the areas of the portions in contact.
A further object of the invention is the provision of a cable formed of a plurality of conductors of sinusoidal form assembled to make point contacts with each other between the nodes of said sines, all other surfaces including said nodes being free to be contacted by surrounding air or any other medium.
A further object of the invention is the provision of a cable formed of four or more conductors each having a series of sinusoidal curves formed therein, said conductors touching each other at point contacts between nodal points of said curves thereby leaving a greater portion of said conductors free of contact with anything but the surrounding air.
Other objects will be apparent to those skilled in the art.
Here's an illustration:
The latest advanced audio cable geometry from the folks at Kimber? Well, if history repeats itself it might be.
Actually it's from patent number 2,218,085, filed in 1938 for a "low loss cable."
I happened across that patent because I was interested in another which cited this one as prior art.
A little over a year ago on another forum, I'd offered up some ideas with regard to making a Litz type cable using a four strand braid of wirewrap wire. During the course of that, I got to wondering if Kimber had ever patented their three-wire braid. They'd managed to get a patent on a series crossover (DiAural) so I was curious if the patent office had rubber-stamped a three wire braid.
So I went over to the patent office web site and did a search.
I didn't find any Kimber patent for a three wire braid, but instead I found that they'd recently been granted a patent on a four wire braid. I was rather taken aback (though not surprised given what the patent office has been granting these days). I'd used a four wire braid variously for years, the first time when I was 16 and cobbled together some impromtu speaker cables using some cloth covered 24 gauge telephone wire my grandfather had laying around. And I was sure I wasn't the first to have done such a thing.
Here's the illustration from Kimber's patent number 6,215,062:
Kimber hails this as their "advanced GyroQuadratic™ field geometry."
I posted a little rant about this on the other forum in the course of which someone pointed out that Kimber's braid appeared to be identical to the braid used by Magnetic Shield Corporation in their Inter-8 cable which they've been selling for 45 years now.
I then realized that I'd seen that same braid dozens of times before over the years in MSC's pages in the EEM (Electronic Engineers Master catalog).
MSC says that the design is patented (though expired) but since the free patent databases don't let you search text prior to 1976 I didn't bother verifying it.
But I recently decided to make a commercial version of the four wire braided 30 gauge magnet wire I've been using and didn't want to get any grief from Kimber's lawyers so I called MSC and got the patent number (2,958,724 filed in 1958, a mere 41 years before Kimber ).
The 1938 patent is cited as prior art in the MSC patent so I thought I'd take a look at it and found it rather amusing that the opening claims of this 65 year old patent read as if it had been submitted in 2003 by some audio cable manufacturer.
Oh, almost forgot, here's the illutration of MSC's Inter-8 from their 1958 patent:
se
Old 17th November 2003, 02:34 PM   #2
FLZapped's Avatar
Hi Steve,
Wow, the new Kimber and the 1958 patent drawings of tre weave are identical in their make-up! The 1938 drawing is somewhat different though. Interesting.
-Bruce
Old 18th November 2003, 05:16 PM   #3
sully is offline sully  United States
Account Disabled
They are not identical..
MSC, the outer group, wires 11 and 14, spiral in a right hand thread orientation, with the inner group, 12 and 13, forming a left hand spiral.
Kimber, on the other hand (sorry, couldn't resist that one), has the outer wires 102 and 104 spiralling LEFT handed, while the wires 106 and 108 spiral right handed..
Obviously, MSC considered only systems located north of the equator, while kimber only south..
I guess it pays to search the patents, to see when they have expired..that at least does not require novel thinking..meaning less aspirin.
Cheers, John
Old 18th November 2003, 05:38 PM   #4
FLZapped's Avatar
Cheers, John
What happens if you hook 'em up backwards?
heh heh......
How'd you come up with a moniker like Sully anyway?
-Bruce
Old 18th November 2003, 09:02 PM   #5
Account Disabled
heh heh......
-Bruce
Backwards...north or south of the equator??
Handedness of a spiral is independent of the direction of the cable..just as it would be a threaded rod..the nut will work from either end..Mirrors are a problem, though..
It's a long story..so I'll tell it..
Started with real name..someone pointed out the problem wth that..so, decided to go with moniker. Kids watching two dvd's at the time..jimmy neutron, and monsters inc.. So, either jneutron, or sully.
decided on jneutron...went a while, found a Jneutron on AA..so, decided to use sully here..but at same time, decided not to change at AA, as Ted Smith was nice enough to let me change from my name..
Cheers, John
The more things change.... JohnG Everything Else 16 22nd November 2006 09:52 PM
I have things sauuuuuce Swap Meet 0 13th October 2006 02:40 AM
Things important to be said..helped by Mr. John Mateus to express things. destroyer X Solid State 22 31st July 2006 07:21 PM
The more things change... Steve Eddy Everything Else 1 7th January 2004 03:10 AM
A few things.... Ziller Everything Else 11 9th January 2002 04:44 PM
Page generated in 0.20049 seconds (52.38% PHP - 47.62% MySQL) with 10 queries
