bass trap design for music room
They are two layers of plastic sheet.
Universal Acoustics Bass Trap 100x100mm Product Description
The Bass Trap 100x100mm treat problematic bass frequencies that can amplify in corners. They can be used in wall to wall and ceiling to wall corners to help control the ‘boominess’ often caused by the room mode effect.
The Bass Traps are exclusively designed and manufactured to the very highest professional standard in VN . Universal Acoustics Bass Traps are cut in a striking contemporary design from Panllet . Perfect for use in Recording and Broadcast Studios, Music Rehearsal Rooms, Audio and language labs, Boardrooms, offices, Staff rooms, Gymnasiums and any open spaces that require efficient sound absorption to improve the audio integrity and intelligibility plus the performance and dynamics of the room.
They are easy to install on most surfaces using non solvent based adhesive.
