Other Applications of Vacuum Tubes
Several DIY solid state amps use light bulbs as incandescent load resistors. For example, the De-Lite Amplifier by Mr. Pass, the SIT amp by Mr. Rothacher, and wrenchone's L'Fake amp. Mr Pass hailed their resultant sound as Organic and different in character than using common load resistors and current source loads. So, why not use the heaters of vacuum tubes in a similar application. Apparently, this idea is not new. Please see the thread in the Pass Labs Form by the DIYer wrenchone which has a title beginning with L'Fake...Its last page shows such applications. I'll reproduce mine in this thread.
Alright Antoinel
Thanks for opening this thread. Look forward to seeing and discussing these types of amps. I'll post my "An Humble Amp" when I can get a readable schematic together.
Later...... Terry |
A valve heater might work better* than a bulb, as it is likely to have greater thermal mass so will introduce less bass or signal envelope distortion. Of course, those people who prefer distortion will prefer to use a bulb.
* in this context, 'better' really means 'less badly' |
curious resistors
Look at Pete Millett's Starving Student Headphone amp. It uses the tube heaters as the load for a mosfet follower. The amp was succesful enough to deplete the worlds supply of 19J6 tubes.
Starving Student hybrid |
Thank you all for your valuable input. I'll post today a picture of the prototype. I wish you a happy, healthy, and prosperous 2013.
1 Attachment(s)
I was pleased with the sound quality. Clear, detailed, no hum and tonally balanced. I'll have more on its subjective and objective measurements in upcoming posts. Best regards |
Schematic of proto amp
1 Attachment(s)
Here is a picture of the schematic of the proto amp. Please go to Posts # 91 and 92 in wrenchone's thread which is partially entitled "L'Fake..." in the Pass Labs Forum for additional discussion of it.
Best |
Can't remember just where, but some guitar amps have been made with preamp tube heaters as cathode resistor for the power tube.
By other uses, I assume you do not mean things like computer logic, thryistor tubes controlling solenoids, and so on. |
| All times are GMT. The time now is 07:41 AM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
