Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 9th November 2003, 08:32 PM   #1
Valerie is offline Valerie  New Zealand
Default Line input to pc audio card
Newbie question - am posting here because I don't know which forum to post in. I was directed to diyAudio.com from a computer forum.
Question: Is it okay to use the earphone output from a cassette tape player as input to the line-in connection on my pc or will there be too much voltage/power/watts/amps or whatever. {Male family members are amateur radio gurus so I picked up a little terminology}
BTW I'm also a newbie on pc's.
Thanks - and apologies if I got the wrong forum.
V...
Old 10th November 2003, 12:13 AM   #2
Valerie:
A) Welcome to the forum!
B) This is probably the correct section to post your question. However, the moderators will move it to the appropriate section if it were not. Having a thread moved to a different section carries no stigma-so don't let that prevent you from posting.
C) You can use the headphone jack into the Line In of a sound card. Turn the volume of the cassette player fairly low to begin with then move it up gradually to prevent any possible overload.
D) Here is an informative thread on the issue. Mr. Feedback operates an electronic repair store, so you can be sure of the answer.
LINE OUT !!!! (Impedance Matching ???)
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 10th November 2003, 05:45 AM   #3
Hello Kelticwizard - thank you very much for the welcome and the knowledgable reply.
V...
Built the DDDAC MKII USB audio card, modified it to feed SRPP tube amp line stage wa2ise Tubes / Valves 0 8th June 2008 03:21 AM
Quad 44 Phono Card swap for line level jives11 Swap Meet 2 18th October 2004 11:49 AM
MAX ! Input level for Santa Cruz card? sam9 Everything Else 7 15th June 2004 10:05 AM
sound card input levels maylar Solid State 3 28th April 2004 10:50 AM
sound card mic input JBL Digital Source 4 25th November 2002 05:16 PM
Page generated in 0.07557 seconds (71.61% PHP - 28.39% MySQL) with 10 queries
