Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 8th November 2003, 09:39 AM   #1
li_gangyi's Avatar
Default Small SMPSU Design
Hiyee,
was looking through the LM2674 from national and wanted to make a simple 12V-5V converter for my Gameboy to be used in a car...so I was wondering how to make the PSU always on as the chip has an on-off function with a -0.1V to 6V limit...help me out plase...not sure where else to ask this question...
http://www.national.com/ds/LM/LM2674.pdf
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 8th November 2003, 11:40 AM   #2
Bakmeel is offline Bakmeel  Netherlands
Bakmeel's Avatar
I can't open the datasheet 'cause acrobat reader is crashing on my PC, but I think it's simple: use a voltage divider on the 12V side with two 1k resistors.
More Power Igor! More Power!
Old 8th November 2003, 11:40 AM   #3
Bakmeel's Avatar
double post.... sorry
Old 8th November 2003, 12:40 PM   #4
li_gangyi's Avatar
Meaning i will have to put in arund 6V...using the voltage divider...hmm seems like a good one...anyone else??
Old 8th November 2003, 12:49 PM   #5
jackinnj's Avatar
ground the on-off pin, it needs a TTL Logic High to disable the device.
a switcher is a better idea than a resistive voltage divider -- the output is regulated so the device will work over a range of load conditions -- Nat Semi has the software for component values right on their website.
Nat Semi has provided a layout for a PCB -- switchers should always be built on a PCB with short, fat traces where the manufacturer recommends.
Old 8th November 2003, 12:56 PM   #6
li_gangyi's Avatar
So I just ground this thing and it will stay off?? Oh yeah...I was thinking of copying the same design...shouldn't be too difficult...just a penknife and a scapel plus a magnifying glass would be ok...and then a check with a dmm...SMD protyping...but I wun be using SMD caps...just the IC itself...or should I go with the LM2575-5.0 which can carry up to an Ampere...hmmm...spoilt for choices here...
Old 8th November 2003, 01:26 PM   #7
jackinnj's Avatar
you can actually get an LM317 -- which everyone has in their junkbox -- to oscillate and use as a switcher. I have used the LM2574-5 -- one of the first "simple-switcher" chips from National in flyback converters. How much current does a Gameboy draw anyway? I have some of the LM2574's just sitting around collecting dust, so let me know...
Old 8th November 2003, 01:38 PM   #8
li_gangyi's Avatar
it's a gameboy light...draws arund 500mA...so an ampere will be a good one...will stick to the above mention parts...anyways I just got some from national as samples...
Old 8th November 2003, 03:42 PM   #9
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Psst... 7805...
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 8th November 2003, 11:16 PM   #10
li_gangyi's Avatar
sheesh....the 7805 can pass 1A I know that...but efficiency sucks big time...and since the gameboy is not an "audio" device...it wouldn't care about all the stuff hat is exiting from the power lead...so I wanna try a SMPSU....I am currently still waiting for the parts to arrive...as soon as I'm done maybe I can post a few pics here...
5000w Smpsu! Emmy Power Supplies 82 22nd March 2012 01:41 PM
Why aren't there any Hi-Voltage SMPSU's ?? tricomp Power Supplies 121 23rd February 2008 09:42 PM
What do you guys think of this SMPSU? simingx Power Supplies 5 18th January 2007 04:36 PM
AC SMPSU filter in use with linear PSU nikosgr Solid State 3 25th February 2003 12:25 PM
Page generated in 0.12571 seconds (70.85% PHP - 29.15% MySQL) with 10 queries
