How to measure frequency response of a 1:1 transformer - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 28th November 2012, 09:46 AM   #1
Gunders is offline Gunders  Norway
Default How to measure frequency response of a 1:1 transformer
How can I measure the frequency response, open circuit impedance and short circuit impedance for a 1:1 transformer with a signal generator and a oscilloscope(+ resistors or/and other passive components if necessary)?
For the frequency response; Can I just connect the generator at the primary and the oscilloscope at the secondary and do a frequency sweep or is the process more sophisticated.
Thank you
Old 28th November 2012, 12:24 PM   #2
DF96 is offline DF96  England
Yes, with care. You need to know about AC potential dividers, so amplitude and phase matter. Frequency response for a transformer depends on source and load impedance, so the transformer itself does not have a response. Also be aware that capacitive loading from scope probes can distort measurements: use a compensated 10:1 probe.
Old 28th November 2012, 02:33 PM   #3
DUG is online now DUG  Canada
What is the designed load impedance for the transformer?
IF it is a 600R 1:1 then I would test it as in the .jpg.
If you are not going to use it in a 600 ohm source system and just drive it direct then eliminate R1.
That is how I would do it.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
in-room frequency response & transient response MCPete Multi-Way 1 8th October 2011 06:31 AM
Simple test for transformer frequency response? bst Tubes / Valves 1 26th January 2010 09:26 PM
Easiest software to measure the Frequency Response -_nando-_ Multi-Way 72 15th July 2007 05:21 PM
How to measure frequency response with a PC? zafira1981 Tubes / Valves 26 1st April 2007 09:53 PM
How to measure frequency response with PC? Emiel Multi-Way 8 3rd November 2005 05:09 PM
Copyright 1999-2017 diyAudio
