A low cost DIY chip based active filter + Amp circuit needed - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 16th November 2012, 06:04 AM   #1
nareshn is offline nareshn  India
Default A low cost DIY chip based active filter + Amp circuit needed
DIY :
1. "Active" filter for two way speaker . Bookshelf only
2. A 10 to 15W "amp" to drive the two ways speakers; prefer chip based to start with.
3.Both the active filter and amp will be mounted together.
Can anyone suggest a suitable DIY design.There are many links shown in this fourm but its not that easy to ship modules/components to India.
Hence prefer a commonly available component design.
Thank you.
Old 16th November 2012, 06:27 AM   #2
Visit sound.westhost.com
and construct the active crossover and an amp of your choice but beware not to blow your small power rated speakers if at all. Select some TDA power amp chip. TDA 2030
The tweeter amp needs to be of double the power than the driver.
Gajanan Phadte
Old 16th November 2012, 06:44 AM   #3
picowallspeaker's Avatar
There's a past number/issue of the Costruire Hi-fi magazine
sommario chf 155
which you may get in a downloadable/viewable format through the net
http://chf.myblupress.it/
It's mainly a Fast ( subwoofer+ full range) , the sub being a little 13 cm in a
double reflex enclosure, the same holding the 8 cm fullrange inside, both powered
by TDA 2050 and OPA2134 ( ??) for L/R crossover at about 160 Hz.
Both drivers are also italian, so...
Old 19th November 2012, 11:58 AM   #4
Thank you for the reply and guidance.
Old 14th October 2013, 03:23 AM   #5
The sites referred to have the details .Is there a company which offer a complete stereo 2.0 kit .
1.Passive or active pre amp with remote
2.Active filter for hi and mid/low
3.A chip based power amp
4.Loudspeaker driver
5.Building instructions
Any guidance is appreciated .
Old 3rd February 2014, 02:57 AM   #6
Audio Amplifier, 30W w/ 2-Way Active Crossover [XAMP-M2] Audio Amplifier, 50W, Mono, 2-Way Active Crossover [XAMP-M2] : Xkitz Electronics, Electronic Kits, Fun Educational Electronic Projects this is closest i could get to for a mini active crossover + amp .
Request team members to point me to a mini bookshelf design.
Dimensions : not more than 10in in ht ; 5in width ; 5 inch width
Which drivers for hi and low : any India drivers (wavecore,pereless...or equivalent ).
Thanks in advance.
Low-cost active crossover module for Hypex UcD amps Al Garay Class D 2 2nd September 2014 07:36 PM
NEEDED diy low cut filter screamersusa Analog Line Level 2 9th September 2010 12:48 PM
low power high quality chip amp needed hamedfazelm Chip Amps 24 9th May 2010 11:29 AM
Low cost dsp based crossover module Crossoverman Multi-Way 38 20th February 2010 11:25 AM
LOW COST circuitsboard for diy amp !!! partyjups Parts 1 27th May 2001 11:17 AM
Copyright 1999-2017 diyAudio
