Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 13th November 2012, 10:22 PM   #1
Default Nikko Popping
I have a Nikko NR-1015 that when I first powered up sounded ok, after about 10 min. a popping started in both speakers then it cut out then returned to the popping. after about half hour the loudest static I ever heard started in both speakers and no matter what I did it didn't stop. The only thing that shut it up was power down. started it up once since then and same thing.......any ideas??????
Old 14th November 2012, 06:20 PM   #2
Mooly's Avatar
If its happening on both channels then the problem could be power supply related. Maybe a dry joint somewhere or a regulator (either discrete or IC) doing something strange.
You need to narrow it down a lot more. Is the noise affected by the volume control for example, does it happen on any input etc etc
A simulation free zone. Design it, build it, test it.
Old 14th November 2012, 08:50 PM   #3
The only thing and I do mean the only thing that stops the noise is power off
Old 15th November 2012, 06:27 AM   #4
Mooly's Avatar
I would check the power supply, check for any loose fuseholders, check the mains switch and also look at the rails on a scope. If both speakers are affected the PSU is the common factor. It could even be faulty reservoir caps.
Try adding some series resistors to the speakers to lessen the noise while you work on it.
Nikko na-850 trd1587 Solid State 7 20th February 2010 06:07 PM
nikko TRM-750 diymax62 Solid State 11 12th November 2009 07:35 PM
Who knows the Nikko Alpha II ? ginetto61 Solid State 4 20th October 2009 04:45 PM
Nikko Alpha 220 GEirin Solid State 4 17th April 2008 08:34 PM
Nikko NA2000 sasbgsas Solid State 0 22nd May 2007 10:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
