Recording? - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 28th October 2012, 07:06 PM   #1
Destroyer OS's Avatar
Default Recording?
I'm sure someone here can point me in the right direction.
So there are a few ideas kicking around in my head for doing sound art (I know, I know, it usually sucks bad, but most people think audiophile qualities don't matter in it, but they do!). One of them involves the fact that I want to record pillow talk as nearfield, dynamic, and real as possible. I'm not sure what kind of recording device I need for this that will be extremely high quality; hearing the amount of moisture in the mouth. If I have to it can be faked between talented actors or something, but what I really want is it to be real.
Thanks for any help!
Old 28th October 2012, 07:10 PM   #2
James Lehman's Avatar
Send a message via Skype™ to James Lehman
I would suggest using the smallest omni electret mic I could find. and close micing the person's mouth.
Old 28th October 2012, 08:10 PM   #3
I don't know what I should plug the mic into. The only thing I do know is I will be using a power filter to keep the sound half decent post-mastering, if it isn't battery operated. It needs to specifically capture the very low tonal qualities that you can feel resonating from someone in close proximity. To the point I may greatly increase those during mastering if I don't feel they are as high as they would have been if you where in the experience. I guess rather I have to make sure I get them, is what I am saying.
Old 29th October 2012, 05:50 AM   #4
One of those tiny little Mylar diaphragm omni electret mics is about the widest freq response you are likely to get without spending mega-bucks. You can buy the naked capsules for super cheap, like only a few dollars and hook them up yourself with a 9V battery a resister and a capacitor.
I used to use them all the time when I was doing recording.
James.
Old 29th October 2012, 06:06 AM   #5
Like this? Goldline TEF04P Phantom Powered Omnidirectional Electret Condenser Microphone | Spectrum Audio
I have zero recording equipment so I have yet to figure out what to capture the recording on. Like the microphone has to plug into something. I imagine a portable unit could be advantageous to this?
Old 29th October 2012, 09:48 AM   #6
SY's Avatar
Close mike will get you far too much extraneous noise- slight motions against the pillow case will be thunderous. Use a hypercardioid or shotgun mike a meter away pointed at the center of the "action."
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 29th October 2012, 04:46 PM   #7
No. Like this:
10 X 6mm Mini Capsule Electret Condenser Microphones
FEL Connectors and Components
An Omni mic actually has much better rejection of extemporaneous noise like wind because the diaphragm is stretched over an almost sealed rear chamber. this controls it well, unlike a cardiod, that is totally open to the air on both sides of the diaphragm that flaps in the slightest breeze like a sail.
You might try a PZM or pressure zone mic. It is an omni electret mounted on a flat plane with a tiny gap.
James.
Old 29th October 2012, 05:04 PM   #8
I'd try a large diaphragm condenser mic and suspend it about 5-10 inches above.
Good ones are switchable between cardioid, omni, figure-of-eight etc. I'd start with omni.
Something like this should do:
sE Electronics sE4400a Dual Capsule Multi Purpose Condenser Microphone
You will need a mic pre capable of supplying 48V phantom power.
Some A-D convertors have those built in.
It might be a good idea to ask this question on a forum like gearslutz.com.
Old 29th October 2012, 06:05 PM   #9
A large diaphragm is exactly what you don't want! Everything about it will work against your goal. That mic actually has multiple elements that work in various phase arrangements to create the different patterns. It is not an almost sealed chamber with a tiny diaphragm, like I posted above.
Like I said, you can get omni capsules for like $1 each. They are used in all kinds of electronics like phones and pocket recorders. They are super cheap, but they also happen to be very good mics. The only problem they present is a bit of hiss from the FET transistor in the electronics that converts the changing capacitance into an audio signal.
All you need is a 9V battery, a resister, a tantalum capacitor, some wire and a phone plug!
James.
Old 29th October 2012, 06:06 PM   #10
SY's Avatar
I would say the same thing about omni. Back in my pornstar days, the sound guy would always use... oh wait, I wasn't supposed to talk about that.
Recording, playbackís poor relation? Post a DIY recording. wakibaki The Lounge 4 2nd December 2010 04:46 AM
recording amp xautumnsashesx Tubes / Valves 0 24th July 2007 03:53 AM
favorite recording... sberube Music 1 27th June 2004 04:55 PM
recording questions muzzi Everything Else 2 27th August 2003 02:31 AM
What an excellent recording~!!!!!!! SteveG Everything Else 3 24th February 2002 02:45 AM
Copyright ©1999-2017 diyAudio
