| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#11 |
What you are looking for is called "proximity effect".
It works with both omni and cardiod mics. It is the region of air that is so close to the source of the sound that it direct couples the source to the mic diaphragm, because, from the low-end up, most of the sound is within less than a wavelength or even half a wavelength. Typically, in a quite room, this area of sound will be WAY louder than any sounds from many feet father away. James.
#12 |
Proximity is important. I need it to be a recording of an intimint place that is so small no human could exist in it (between two people close enough to kiss,l aying on a bed).
#13 | |
It manifests itself as a considerable bass boost. Generally small diaphragm condensers do not sound particularly nice on voices. They are good for acoustic guitars or drum overheads though. Large diaphragm ones sound much more intimate IMO. http://en.wikipedia.org/wiki/Proximity_effect_(audio) |
#14 |
I am actually feeling tempted to use two microphones, for two channels because it would aid in the playback experience.
Can anyone comment on a recording device? I'll probably ask for opinions at gear slutz (I would of posted there first, but I didn't know which recording forum was serious vs. all the boners that record stuff poorly these days) |
#15 |
Most Lavalier microphones (made for voice) are electret omni capsules.
#16 |
Something like this should do the trick:
Firewire audio recording interface 6 IN 6 OUT | Echo Digital Audio |
#17 | |
Which isn't a problem because they are not meant to. If you hear a very intimate sounding recorded voice like acoustic jazz and such like you can pretty much guarantee that the mic in question was a large-diaphragm condenser and probably half of them were Neumanns. |
#18 |
He's not looking for any kind of typical vocal mic here.
No one is singing! He's looking for a special effect. James.
#19 |
Personally, I'd throw the kitchen sink at it. Couple of headset/lavaliers , couple of large format condensers close mic-ing, couple more further away catching room ambience, one or two boundary mics dotted around and maybe even SY's shotgun mics as well. Then you can sort it out in the mix.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#20 |
Hm I think one mic between them, and one inbetween their chests will be perfect.
That firewire thing looks great. Too bad I need an Apple to use it! Right now I run Linux and the only thing worth using for it is $1600. I've heard good things about the Apogee Duet as well. They all appear to have the same basic specs but... I want good sound not specs! What about this mic? Rode NT2A Variable Pattern Microphone at zZounds Either I have to have circle 8 or two mics. Circle 8 should work great because when one person is talking I can pan it harder to one side, giving an impression of inbetween; when they both speak it'll be equal on eachside of the affect of that will be enhanced feeling over overwhelming. I got to post over at GearSlutz perhaps. My friend recommended looking at Tweakheadz as well. What I don't know how to do yet is seperate out the people that about numbers, specs, and the people that are about actual quality sound. I'm so excited! if I get the $650 sE mic I'll have to rent out recording services to my friends. Recording well ain't cheap! But I know a few tricks about the non-gear side for good sound (I have great ears for stuff, and have done a little professional studio time, real little, but conceptually I get it). |
| Recording, playback’s poor relation? Post a DIY recording. | wakibaki | The Lounge | 4 | 2nd December 2010 04:46 AM |
| recording amp | xautumnsashesx | Tubes / Valves | 0 | 24th July 2007 03:53 AM |
| favorite recording... | sberube | Music | 1 | 27th June 2004 04:55 PM |
| recording questions | muzzi | Everything Else | 2 | 27th August 2003 02:31 AM |
| What an excellent recording~!!!!!!! | SteveG | Everything Else | 3 | 24th February 2002 02:45 AM |
