cheap cables - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 26th October 2012, 07:30 PM   #1
henrylrjr's Avatar
Default cheap cables
My latest thought has been to put 3 lengths, of solid 22 awg OFHC CDA101 annealed temper copper wire , inside 3 seperate lenghts of cotton sleeving with a low dieletric constant of about 1.3. Braid 4 groups, each made up of 3 cotton encased wires, and insert each braided assembly into 4 very low dielectric ptfe tubes. Seal the ends of the ptfe tubes, with silicone sealant and, twist two pairs and secure twists with shrink wrap about every foot. The two assemblies would allow amp to speaker connection for two speakers in a stereo setup.The 3 braided wires, should equal about 17awg which I thought, would be sufficient for 11.5ft lengths.
Has anyone tried this or know of a potential problem with this approach?
Old 26th October 2012, 08:01 PM   #2
DUG is offline DUG  Canada
use non-corrosive silicone
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 26th October 2012, 09:31 PM   #3
tvrgeek is offline tvrgeek  United States
Not looking for a fight, but I have to weigh in yet again.
The biggest potential problem is you are spending a lot of time and money on something that is totally irrelevant for sound when you could be building better speakers, better amps, or buying more music.
I find 16 gauge zip cord to do just fine. I have to admit, I like the expensive fine strand stuff from Madisound because of it's flexibility. For my mains, I found 300 Ohm twin-lead works quite well. (old copper, not copper over iron) I just tin my ends and use either simple binding posts or terminal strips.
I don't suppose you know that foundries ADD oxygen to copper to float out impurities to make it a better conductor?
All that work on 11 feet of wire and you are going to feed a crossover and voice coil from an amp with an output choke and iron wire emitter resistors through a cheap relay and maybe a fuse. Please take a step back and consider the entirety of the system. Being a cheap-skate as well as an engineer, I spend my money where I will get results. Can speaker wire make it sound different? Yea, it can make it worse than zip cord.
Old 28th October 2012, 01:30 AM   #4
henrylrjr's Avatar
Default cheap speaker cable design mods
This is not a reply to the Zip cord proponent but to all. I was thinking that, while pulling the solid wires into the cotton sleeves, I would coat the wires with caig pro gold by holding a piece of the pro gold sheeting around the wires. Any thoughts on this?
Old 28th October 2012, 01:38 AM   #5
Speakerholic
Cal Weldon's Avatar
Yes I have thoughts. I want to see the rest of your system to know if what you are considering has any validity. Not to put a damper on the project but you must have an incredible set-up to even be considering this. If you have exhausted all other avenues for system improvement then this might be the right path. The problem I am having is that you use the word 'cheap' in your title.
Pictures and descriptions speak volumes.
planet10 needs your help:
Let's help Ruth and Dave
Old 28th October 2012, 02:50 AM   #6
diyAudio Member RIP
The whole process is nowhere near complicated enough to sound any good,
rgds, sreten.
Old 28th October 2012, 04:06 AM   #7
Speakerholic
Cal Weldon's Avatar
Funniest thing you've said in years.
Old 28th October 2012, 05:18 AM   #8
Old 28th October 2012, 06:11 AM   #9
frugal-phile(tm)
planet10's Avatar
Great comment sreten
You want cheap? Go get 2 lengths of solid core CAT5 network cable (preferrablly plenum with teflon insulation, but that is ~10x as expensive, so not as cheap), and extract a twisted pair and use that. You'll have enuff left over for 3 more systems.
Thick guage wire is highly over-rated.
I do believe that wire makes an audible difference, is very system dependent, and often more about how it drives the amp crazy than anything else.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th October 2012, 11:26 AM   #10
Dave, Don't you think the solid core is a bit too susceptible to fatigue and breaking? Otherwise, I completely agree with everything you said. This time.
Rca Interconnects With Rg Cheap Cables juluska Everything Else 13 30th March 2011 05:31 PM
cheap as chips high end speaker cables samtheman23 Everything Else 22 29th November 2006 08:12 PM
ssabripo's DIY Speaker cables Tutorial (cat5e based): Audiophile wires on the cheap! ssabripo Everything Else 1 26th October 2006 02:32 PM
Alpine Mp3 Player, Jl Amplifier, Jl Subwoofer, Cables ( Cheap) guzonja Parts 0 21st October 2006 09:40 PM
Alpine Mp3 Player, Jl Amplifier, Jl Subwoofer, Cables ( Cheap) guzonja Swap Meet 1 21st October 2006 02:56 AM
Copyright 1999-2017 diyAudio
