| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#31 |
I"m not guessing. Having set up laser light show during the day, I can say for sure that the sun destroys them. They come back just fine when the sun goes below the horizon. No mystery there.
#32 | |
It's all part of a commie plot to sap and impurify our bodily fluids. |
#33 | |
You would very easily as Nikola Tesla postulated, destroy the earth from resonance. He said it would split like an apple! no wonder they thought he was a mad scientist ![]()
#34 |
It is quite possible to blow a laser diode, with some effort, by causing a reflexion on the integrated monitoring photodiode ( by saturating it).
How it may work? For constant power lasers a photodiode generates a current proportional with the optical power. This is converted to a voltage which is compared with a reference that sets the CW power. Typically this is done at max 80% of the rated diode power to allow for aging and get good service life... ..and to protect the diode against accidental overshoots in the error amp. With ill conceived electronics (no poles to control rise time, no fast over-current limiting and with the power adjusted to 100% eventually) it only takes a few usec after the occurrence of a reflexion to get a "supernova". Generally it happens when adjusting the focus, the beam itself gets reflected on impurities on the back side of the lens or on other "bad" optical surfaces. As for the sun... the only thing playing in sun's favor is its "wideband" but other than that all you need is a shutter...Wait, it may work afterall... ![]()
Make two for stereo |
| Changing Lasers | Pironi | Parts | 1 | 5th February 2008 07:17 PM |
| Big supplier for Lasers | apassgear | Digital Source | 0 | 4th March 2007 05:06 PM |
| Lasers, Tubes, and PCB | jjimison | Tubes / Valves | 1 | 3rd December 2006 08:43 PM |
| Help: Sun Audio Kits where from? EIFL, ELEX, Sun Audio? | Gaga | Tubes / Valves | 2 | 31st March 2006 01:51 PM |
| Lasers for security system | polsol | Parts | 5 | 23rd November 2004 02:28 AM |
