Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
installing printer ?
Old 13th September 2012, 05:24 PM   #31
from post1
I tried installing a printer option, but it gives me option for LPT1, 2, 3, serial 1, 2, 3, 4.
Which do I select? com1 did not do anything.
I tried installing driver, but 6050 was not on the list. I tried update windows hoping to find a new set of drivers. The PC hung.
from post25
that's where I am getting stuck.
Add a printer gives a screen that asks for connection. It defaults to lpt (parallel) I don't have a parallel printer port.
It then asks for the printer .
Brother is at the top of the list but in the Brother options there is no hl6050.
Two stops.
regards Andrew T.
Old 13th September 2012, 05:29 PM   #32
there is information in printer properties.
but the drivers option does not work.
it also says: this device is working properly.
regards Andrew T.
Old 13th September 2012, 05:34 PM   #33
macboy is offline macboy  Canada
Often with these older printers that have a USB port and LPT ports, the USB port is implemented as a simple USB-to-LPT bridge, not as a "proper" USB interface. This works, but it causes confusion since the printer does not show up as a USB device (not a USB printer, anyway), and the port that you use with the printer is actually an LPT port.
If this is the case with your printer, and if your computer has no actual LPT/printer port, then the printer's USB-LPT bridge should enumerate itself as LPT1 when plugged into the computer. Try using LPT1. (If your computer has a printer port, it will probably be LPT1 and if you plug in this type of "USB" printer, it will create a LPT2 port).
Old 13th September 2012, 05:43 PM   #34
Oh!
Is that a complete set of instructions? Can I follow them to the letter?
Do I use the usb cable?
Where do I connect the cable?
Do I need to tell the printer anything?
Do I need to reboot the computer or re-boot the printer?
Do I select lpt1?
What after that? since I don't see the hl6050.
regards Andrew T.
Old 13th September 2012, 05:49 PM   #35
Vdi,
my PC is talking to you !
regards Andrew T.
Old 13th September 2012, 05:58 PM   #36
If you have installed the driver package, then:
  1. Open "Devices and Printers" in the Start menu (or whatever they call it now).
  2. click "Add a Printer" (where the menu bar should be).
  3. Take a look at the list of ports in the drop-down box. Maybe one has a name including Brother or HL6050 or something. Or look for one with USB in the name. Finally, pick LPT1 if nothing else looks interesting.
  4. Pick Brother in the list of manufacturers and hopefully the HL6050 is in the list of models. You could also choose "Have a disk" and point it to the directory where you extracted the downloaded drivers.
  5. If this didn't fail then try printing a test page.
Old 13th September 2012, 06:01 PM   #37
I tried com1 as the first of the serial ports. did nothing
I tried usb002 as the only one that looked usb compatible. did nothing.
Not tried lpt1 yet.
the hl6050 is not on the list. That's why I downloaded the Brother drivers direct from Brother's site.
regards Andrew T.
Old 13th September 2012, 06:09 PM   #38
Not tried lpt1 yet.
COMx are serial ports, definitely not one of those.
USB00x sounds right, my older "USB" printers show up as such.
The HL6050 should be in the printers list, after you have successfully installed the drivers. If it isn't, then you haven't, and that's a problem. But you can try the "have a disk" button which should install them at that time.
Old 13th September 2012, 06:25 PM   #39
Success.
VDI remotely made the connection for me.
Prints text and schematics.
I'm happy again.
Just got to sort my sound card. But that will be later.
regards Andrew T.
installing printer ?Hide this!Advertise here!
Don't throw away that printer just yet! GloBug The Lounge 3 7th December 2011 01:36 PM
Printer recommendation please ? thermal runaway Everything Else 5 7th April 2009 06:59 PM
HP Printer problems...need help. ashok Everything Else 0 3rd March 2008 12:35 PM
need printer suggestions sss Everything Else 11 25th March 2006 05:40 PM
PCB making with printer Dwiel Parts 9 26th September 2004 11:49 PM
