Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 13th September 2012, 03:31 PM   #21
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
You can always move it back up after the printer gets working.
To recap, we a re trhying to get that file deleted from the print queue.
We need to get the Printer Spool service stopped first or else the file is in use.
I build, therefore I am.
Old 13th September 2012, 03:34 PM   #22
post15 second method. Got as far as users
It shows ONE user. No option to right click on any part of the screen.
It reads
Andrew and underneath the icon shows administrator.
Old 13th September 2012, 03:35 PM   #23
But the spool printers folder reports as empty.
and Guest is OFF.
Old 13th September 2012, 03:36 PM   #24
Electrons are yellow and more is better!
peranders's Avatar
Since I'm run Windows on my Mac I clearly notice the difference when connecting printer. On Mac in just works and on Windows I have to work for it.
For me it is downloading the driver.
Add an printer.
Then it works.
/Per-Anders (my first name) or P-A as my friends call me
Tube Buffered Gainclone in work |Thread
Old 13th September 2012, 03:41 PM   #25
Per,
that's where I am getting stuck.
Add a printer gives a screen that asks for connection. It defaults to lpt (parallel) I don't have a parallel printer port.
It then asks for the printer .
Brother is at the top of the list but in the Brother options there is no hl6050.
Two stops.
Old 13th September 2012, 03:47 PM   #26
vdi_nenna's Avatar
OK, good.
Still need to understand why it's not working. So, best way to tell is to look for events.
Righ click computer> Manage> on left look for Event Viewer.
Double click Windows Logs. Below will be Application, Setup and System.
Select each, one at a time, and look for errors or warnings. Error are Red Exclaimation points and warning are yellow. Double click to open an error.
We are look for anything that can point to a reason for the printer problem. Since you installed today, look for today's time and date when you installed or tried to print.
Yuo can hi-light a message description, the control C or Ctrl+C. paste it in a text doc or into a post.
Old 13th September 2012, 03:55 PM   #27
But the driver files went into temp.
I retried and put the same files into C.
I doubt that either is a valid installation.
Old 13th September 2012, 03:58 PM   #28
vdi_nenna's Avatar
I sent you a PM. Check it out.
Old 13th September 2012, 04:14 PM   #29
Now the Forum has auto logged me out. Lost my reply.
I have to manually log out then log in and now retype my post. here goes.
there are two warnings in 24hrs. no colours. 4entries: rpc, dns, user profile & restart manager.
there are lots of information, again no colours. 23 in last hour and 782 in last 24hrs.
Audit success has 4 in last hour and 200 in last 24hrs. again no colours, just plain B&W.
Old 13th September 2012, 04:16 PM   #30
vdi_nenna's Avatar
Neither is an installation, that's right. I just downloaded and extracted the file from Brother and it's only drivers.
In Printers, right click your printer, select Printer Properties
One of the tabs should give you an option for installing a new driver or to change a driver.
You are going to have to tell it where the driver is, so select the option that will allow you to drill down and to the Temp folder where the driver is located. Select ENG for English, inside should be a file for the driver. Only one will appear.
Don't throw away that printer just yet! GloBug The Lounge 3 7th December 2011 12:36 PM
Printer recommendation please ? thermal runaway Everything Else 5 7th April 2009 05:59 PM
HP Printer problems...need help. ashok Everything Else 0 3rd March 2008 11:35 AM
need printer suggestions sss Everything Else 11 25th March 2006 04:40 PM
PCB making with printer Dwiel Parts 9 26th September 2004 10:49 PM
Copyright ©1999-2013 diyAudio
