Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
How to tell the ingredients of wood oils
Old 8th September 2012, 12:30 AM   #1
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
Default How to tell the ingredients of wood oils
I have been reading/looking for a nice finish for my flexy rack and finally decided to use oil.
The only one I could find on the local market was Teak oil. I got two cans that seemed "decent" on the outside
Unfortunately none of them specifies the ingredients, so I have been looking for ways to tell what to expect from them.
I have to say here that I am not particularly experienced in woodcrafitng and what I write below is completely from my observations. Feel free to correct or add to my rant.
The first indication I guess should be the smell.
Both of them had a very strong thinner smell, but the one had a distinct waxy scent as well.
While reading on inet, I came accross a page where the writter (sorry I do not remember the page) suggested to get a few drops on a non-porus surface like a glass and let it dry. After the thinner evaporates, the remainder should be either oil or wax or varnish. You can see below the results of my oils after 24 hours on the glass.
This one is sticky to the touch with no oily feel to it. And from its color, I get that it s probably just plain thinned varnish, with minimal or no oil at all. It s smell (almost gone now) is still quite bad. Not from the thinner and not oily or waxy at all.
The other one, (the one with the waxy scent) is not sticky at all. It has dried and left a rather elastic solid that feels like wax. Its smell (rather faint again) feels oily and waxy.
So I think I have found my winner on the second one...
I hope this helps someone else. Of course again, I am by any means a professional or even particularly knowledgeable about woodcrafting, so please feel free to correct me or leave your own tricks on how to tell which mixes are legit
Old 8th September 2012, 05:11 AM   #2
DUG is online now DUG  Canada
If you list the brands and types that you tested it would indeed help other people so they would not have to make the same test.
Just a suggestion
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 8th September 2012, 09:41 AM   #3
dimkasta's Avatar
About the type, I mentioned that both are Teak oils. Now about the maker, the test is pretty simple so I didn t thought it would matter a lot.
The first one is Duro Stick Teak Oil (made in Greece) and the second is International Teak Oil (Made in UK)
Old 8th September 2012, 10:22 AM   #4
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Just a quick point, the formulation of the oil is likely comercially confident, so won't be published on the can. However you can use this to your advantage, as different brands may be suitable for different woods.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 8th September 2012, 10:37 AM   #5
On Hiatus
SY's Avatar
It may not be on the can, but you are entitled to a copy of the MSDS. It won't have complete formulation info, but the solvents and any hazardous ingredients will be disclosed. That will give you several clues.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 8th September 2012, 10:45 AM   #6
pinkmouse's Avatar
Is that the same as our COSHH documentation SY?
Old 8th September 2012, 10:55 AM   #7
dimkasta's Avatar
I applied a layer of the second one by cloth and it dries too fast feeling sticky... It seems it is more waxy/varnishy than oilly...
I will have to work with much thinner applications wiping them off fast
Old 8th September 2012, 10:58 AM   #8
On Hiatus
SY's Avatar
Probably part of that program, but the document you want is still called an MSDS in UK and Europe. If it's not packed with a chemical, you can demand it from the manufacturer or the agent who sells the product.
Old 8th September 2012, 11:05 AM   #9
pinkmouse's Avatar
Indeed, not letting the oil sit on the surface of the wood for too long is key, rub off as soon as you've finished the application. Lots of coats is the key - as the old mantra goes: "Once an hour for a day, once a day for a week, once a week for a month, and once a month for a year".
How to tell the ingredients of wood oilsHide this!Advertise here!
Household ingredients pcb etching!!! Rodeodave Construction Tips 2 7th May 2011 09:01 PM
What ingredients to use in a music first subwoofer? (or two?) jakja83 Subwoofers 17 26th April 2011 02:07 PM
Wood Finishes kach22i Construction Tips 23 24th March 2011 05:52 PM
Solen Fast Cap vs ASC film/oils in PS Curly Woods Parts 4 3rd September 2008 05:14 PM
Which wood? Spasticteapot Multi-Way 28 6th August 2007 10:57 PM
