diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Everything Else (http://www.diyaudio.com/forums/everything-else/)
-   -   Tivoli Parts (http://www.diyaudio.com/forums/everything-else/219151-tivoli-parts.html)
russmacman 6th September 2012 12:15 AM
Tivoli Parts
My stations for my Tivoli model one is so far off the actual dial that at the end of FM i can only pickup around 104.5 and not 107 or so. It's having problems tuning into a station and if you just touch the dial the station is gone. Is there a way to adjust or is there a replacement tuner that i can install? This version has the aux setting. Thanks in advance.
DUG 6th September 2012 02:43 AM
If it is just out of tune you could re-align the LO and possible the RF tuning stages using known radio stations as signal sources. The IF tuning (if it is adjustable) I would not touch without an FM generator. It would be best to have some sort of schematic or guide to show where the adjustments should be made.
If it is "broken" then that is a different story. Schematics or experience and test equipment would be a necessity.
Good Luck
russmacman 6th September 2012 10:45 AM
Tivoli Parts
Thanks for the reply. That's one of my problems. I find so little on line for parts, manuals or photos for this unit. I'm willing to adjust ht e tuner with a known station, but don't know what to adjust and where. Thanks. Russ
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
