| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I am working on a PCB layout, or rather a Veroboard layout, and
found that in this particular case it would be very useful if op amps came in two variants, with symmetrically reversed pinouts. Of course it is not realistic to manufacture dual versions, but anyway, in this case it would make it possible to do a simpler and better layout. So, I got this idea, why not just bend the leads over 180 degrees and voilá, you have a mirrored op amp. Of course once can put the op amp on the opposite side of the board instead, but that seems a less preferrable way, especially if using PCBS with groundplanes. I would be surprised if I were the first to get this pretty obvious idea, so I am just curios, have any of you used this trick already? (Actually, I decided not to do it in this particular case, since I will use sockets and will want to swap op amps frequently, and don't like the idea of having a large bunch of flipped op amps lying around. I will keep it in the back of my head for future use, however.) |
#2 |
How about wiring up an adaptor using DIP sockets so that the stack looks like this:
PCB - DIP - Adaptor DIP - IC :)ensen.
Those who claim to be making history are often the same ones repeating it. |
#3 |
Yes, but that is a complex solution with bad electrical properties.
Just bending the pins is done in a few seconds, and shouldn't be any problem if you're careful and don't bend them back again. |
#4 |
Electrons are yellow and more is better!
You can bend the legs 180 deg but not too many times....
Only a few IC's have mirrored pinning. Some DAC's have it because they are intended for single sided pcb's and tne IC is SMD. Have many has used this thick?.... have many have missed "top view" and "bottom veiw" when you have made a pcb, hands up? To be honest I have never done that but I know a couple of people which have.
/Per-Anders (my first name) or P-A as my friends call me |
#5 |
(Hand held up)
I managed to do this on a small number of 'horribly expensive to make' hexagonal PCB's . It would have been too embarassing to get them remade so bending the pins was the only option - luckily there were only a few DILs and there was no chance that anyone would ever see them again (too contaminated to ever handle again) !! They worked fine BTW ...Dave /don't try this at home ... |
#6 |
DRC,
That's another reason to do it, of course. Didn't think of that. I would probably have done the same in your situation. |
#7 | |
#8 | |
it have some other radio-specific purpose? BTW, it should also have the side-effect of slightly more efficient cooling, since we end up with something like the Intel flip chip package. This effect is probably negligible unless a heatsink is used, however. |
#9 |
i think it's mostly to get some of the pins as close as possible to the ground plane.
the other popular technique is the "Manahttan" printed circuit board -- for point to point wiring of HF circuits you just tack your components "dot to dot" which are laid out like the streets of New York. |
#10 | |
Why would that make a difference? Doesn't the ground plane usually run over the whole surface of the board so all pins are equally close to it whatever way we mount it? Or do you mean it is in order to get the return currents to go where you want them in the ground plane? That would make sense. |
| Page generated in 0.11203 seconds (72.28% PHP - 27.72% MySQL) with 9 queries |
