Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
low noise replacement for BC547, BC557, BD135, BD136
Old 4th August 2012, 06:01 PM   #11
xslavic is offline xslavic  Moldova
Can sc1815 be considered a direct replacement for BC547 in audio applications,without changing the B base resistor?
Old 4th August 2012, 06:46 PM   #12
Mooly's Avatar
In general yes. It's a "cooking grade" NPN like the BC547. Just make sure that you don't exceed the ratings in the data sheet.
No components should need altering to use it.
Old 4th August 2012, 08:31 PM   #13
Default ok
I ment in this circuit,thanks!
Old 5th August 2012, 07:52 AM   #14
Mooly's Avatar
Yes, they would definitely be 100% OK for that.
[The circuit is a little unusual just seeing it in isolation. The inputs are very very low impedance (a virtual ground). Is it used as an I/V convertor from a DAC ?]
Old 5th August 2012, 01:47 PM   #15
Yes,I'll use it as I/v converter for dac , in dual mono ,and I'll need two of these as a result i think I get xlrafter the transistors at 3.16v if I'm not wrong but was afraid of the base resistor and the difference in freq 80 vs 300mhz
Old 5th August 2012, 01:49 PM   #16
Yes low impedance but I changed the 320 ohm Res to 195 to compensate for the higher output
Old 5th August 2012, 08:28 PM   #17
Mooly's Avatar
The base resistors are OK left at 51 ohm. They isolate the opamp output from the B-C and B-E junction capacitance of the transistor and prevent any stability issues. The absolute value won't be very critical.
Absolutely no problem with the different ft of the transistors either.
low noise replacement for BC547, BC557, BD135, BD136Hide this!Advertise here!
Low noise transistor and noise figure Real_Macgyver Solid State 28 27th July 2012 10:42 AM
Red LED noise. GK Solid State 5 14th December 2006 04:12 AM
anyone tried this for low noise 5v? mlloyd1 Digital Source 1 25th May 2006 01:06 PM
Hum and Noise with Ono rsbay Pass Labs 0 26th February 2006 01:51 PM
Noise Bukitoo Analogue Source 2 17th March 2004 03:37 PM
Copyright ©1999-2017 diyAudio
