| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Disable Java runtime NOW !!!
General Forum There are now warnings galore for this security vulnerabilty. Check Google and it will be seen there is no patch available yet. SandyK |
#2 |
Its Java... whats new
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#3 |
Thanks for the heads-up.
![]() My son actually told me about it yesterday, but I promptly forgot.
#4 |
Java has always been a security nightmare. I stopped installing the JRE on my PCs nearly 10 years ago because of it.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#5 |
java 6 is safe.
#6 |
SUBJECT
Threat: Java 1.7.x critical vulnerability with remote code execution OVERVIEW A new Java exploit allows remote attackers to execute arbitrary code via a crafted applet. User must visit a website with malicious code to successfully execute the attack. IMPACT The attack might result in an attacker gaining full access to the victim computer. AT RISK Java JRE 1.7.x running as an web browser applet. Java 1.6 is not affected. To check, which Java version is installed, 1. Click "Start" 2. Select "Run" 3. Type "cmd" 4. At the prompt, type "java -fullversion" You might also go to the website How do I test whether Java is working on my computer? and click "Skip installation of the current version and test the currently installed version of Java". RECOMMENDATION The xxxx highly recommends to disable Java plugin in a web browser. Please, follow instructions on given website: How to disable Java on everything ? Computer Chips & Hardware Technology | Geek.com 8/ to disable Java in your web browser. ADDITIONAL INFORMATION • Links o US-CERT Vulnerability Note VU#636312 - Oracle Java JRE 1.7 Expression.execute() and SunToolkit.getField() fail to restrict access to privileged code
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk JA-88D Class A, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
| 8 Pcs Precision Devices PD2150 vs. 1 Pcs Fostex FW800HS - Pros & Cons wanted | tiefbassuebertr | Subwoofers | 0 | 2nd March 2012 07:12 PM |
| 10 pcs LM3886T | daedalus | Swap Meet | 3 | 28th March 2009 03:39 AM |
| used psu for PCs | bigpanda | Everything Else | 3 | 20th February 2008 06:33 AM |
| Subjectivism with PCs | DCPreamp | Everything Else | 4 | 11th August 2007 06:19 AM |
| 4 pcs 10" carwoofers = 2 pcs homesubs? | FE3T | Subwoofers | 1 | 28th December 2004 05:45 PM |
