eject problem - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 26th August 2012, 06:22 PM   #1
sb1 is offline sb1  United Kingdom
Default eject problem
hi there i have a radius 1000 and citronic mpcd s6 they both have the same cd drives the lasers want so i replaced them but on 1 of the players it dont eject inless u tap the top of cd drive they are slot cd drives 1 that suck the disc in any ideas how to fix it ? many thanks shaun
Old 27th August 2012, 06:17 AM   #2
Rubber belt may be defective/loose.
Gajanan Phadte
Old 27th August 2012, 09:03 AM   #3
u mean this 1
many thanks shaun
Old 27th August 2012, 09:19 AM   #4
just another
wintermute's Avatar
Shaun, I fixed the spelling of eject in the title
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 27th August 2012, 11:19 AM   #5
thanks tony
Old 27th August 2012, 03:03 PM   #6
PlasticIsGood's Avatar
If you remove the belt you may be able to operate the mechanism by turning the pulley. That will enable you to feel if the mechanism is sticking, and observe where.
Cleaning and appropriate lubrication may help, especially on sliding parts and cams. Use only 100% synthetic grease, very sparingly. Thoroughly wash the belt with soap and water, rinse and dry. Clean pulleys...string is good for this if you have some handy.
Could be electrical...if you eject with the belt off does the motor spin OK?
Old 27th August 2012, 03:54 PM   #7
gduran is offline gduran  United States
I have the same problem with my American Audio Velocity. CD-1 will not load or eject cd's without numerous trys when loading and using a small screwdriver to slight manipulate the cd to eject. This is SLOT load also NOT tray load. Any advice would be greatly appreciated.
Blessings to all
Old 30th August 2012, 10:43 AM   #8
My mac was having the same problem. The rubber roller that moves the cd, ages/damages and creates this problem.
Gajanan
Old 30th August 2012, 07:50 PM   #9
Thank you for the response Gajanan. Did you have to replace the rollers or were you able to improvise with a fix that did not cost you an arm and a leg. It seems like a simple problem.I was hoping I could just do some cleaning of the cd slot and the mechanical parts to resolve the problem. Thanks again for the advise.
Glenn
Old 31st August 2012, 09:48 AM   #10
The rubber on the steel rod becomes soft. If there is some product available by which u redo the rubber on the roller.
Here nothing is available for such repairs. I used the drive till I could and then used an external USB drive. Few days back, the MAC died and I now have a DELL.
Gajanan Phadte
Rotel RCD971 won't eject when empty corbijn Digital Source 7 22nd October 2010 07:35 AM
pioneer deh-p9400 cd eject problem ppia600 Car Audio 0 9th April 2009 03:53 AM
ever had your H/U refuse to eject a CD? slicey Car Audio 3 19th March 2007 06:08 PM
Pioneer DEH-P9200R Cd Eject Problem....HELP!!! slizm Car Audio 0 9th February 2004 10:51 PM
Copyright 1999-2017 diyAudio
