Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 22nd October 2003, 09:51 PM   #1
Question CATV amp
I am considering making a small CATV amplifier for my home. I was plaining on using simple op-amps for a gain of 10dB or so. Anyone have any schematics or websites that cover this material?
Or better yet, have any first hand experience?
Old 23rd October 2003, 03:51 AM   #2
ashok's Avatar
Default RF amps.
You can check out the Motorola site. They make modules for CATV amplifiers. I can't remember any model numbers.
Try http://e-www.motorola.com/files/rf_i..._lib/DL209.pdf
http://e-www.motorola.com/webapp/sps...?nodeId=03fvrv
http://e-www.motorola.com/webapp/sps...20819882157623
It might be better to use modules than trying to build it from discrete parts.
Cheers.
AM
Old 23rd October 2003, 08:13 AM   #3
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
There are a number of CATV standards.
Assuming that yours is the simplest simplex system, then an RF distribution amp 80MHz - 850MHz would do.
The (UK) cost for one of these is less than the component cost for making one.
If you do decide to try anyway, then the solution I used (many years ago) was a BFY90 or BFR90 transistor in common emitter. This must be mounted on a ground plane with very small "non-inductive" resistors. Lead lengths 1mm or less. Decoupling caps must be 1GHz types (feed-through types are best).
Still wanna do it? I'll draw you a schematic and layout if you're serious
There are probably better transistors now. You might not get the full 10dB out of 1 stage.
Old 23rd October 2003, 03:05 PM   #4
Well, sound like more work then i really wanted to do. Might as well go to Radio Shack and get one for 20$ or so.
Thanks for the feedback.
CATV box with CC and volume? theAnonymous1 Everything Else 4 19th August 2005 04:58 AM
CATV/Sat Splitters ??? FrankRoss Everything Else 1 27th December 2002 02:22 PM
Page generated in 0.07356 seconds (68.91% PHP - 31.09% MySQL) with 10 queries
