Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 22nd August 2012, 12:17 AM   #1
viewgsm is offline viewgsm  United States
Question merging headphones output to 1 speaker
Hello,
I have an output from a chip that drive headphones
PO: 13 mW (RL = 32 Ω)
PO: 25 mW (RL = 16 Ω)
I need to drive a single 8ohm speaker (.25w) instead of the headphones,
both channels share GND on the chip, can I just connect L to R and and feed that to the speaker (with GND to the other side of the speaker)
will I get double that output ?
Old 23rd August 2012, 02:40 AM   #2
maybe, but it's more likely that you'll get smoke & a dead amp...
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 23rd August 2012, 03:09 AM   #3
Kindhornman's Avatar
viewgs,
I think what you want to try is one output on each side of your speaker. I can't say this for sure but if you tie the two outputs together I think that you will smoke the chip amp. I think that most headphone amps are made to drive 600 ohm loads, at least that is what I remember. Leave the ground wire out of the loop.
Old 23rd August 2012, 05:07 AM   #4
25 mW will not drive any speaker to listening level.
Gajanan Phadte
Old 23rd August 2012, 06:32 AM   #5
sofaspud's Avatar
+1
You'd be much better off using a conventional two-resistor summing circuit feeding a LM386.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 24th August 2012, 01:51 AM   #6
Ron E is offline Ron E  United States
Ron E's Avatar
Depends on listening level and sensitivity 10* log(.025)=-16dB, so it will drive a Klipschorn to 87dB peaks, and a typical home speaker to ~70dB peaks
Running an output to each speaker terminal will give a L-R or R-L signal.
A summing circuit to a small amp is the right answer.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. —Aldous Huxley
DAC xlr output to headphones? SonicSonar Headphone Systems 10 13th January 2012 11:54 PM
headphones output quilla333 Solid State 1 29th June 2010 04:16 PM
Connecting headphones to guitar amp speaker output mike6182 Instruments and Amps 6 21st November 2007 10:20 AM
Headphones output to line level Simpleton Parts 1 13th May 2007 09:54 PM
headphones on speaker out doc Solid State 1 16th January 2002 08:04 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
