Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 15th September 2006, 11:22 PM   #71
bulgin is offline bulgin  South Africa
Default Aluminium Glue
Hi Roberto
OK here you are. I make phono carts and the stuff I use I buy from a local firm called Pratley. The type is 'Special Performance Industrial Adhesive', Grade 020. See www.pratley.com
I point out I have now connection with this firm, I only use their glue which is is a two-part epoxy of most extraordinary strength.
I made numerous trials over a 5 year period and this stuff is perfect. As you know aluminium oxidises instantly whenthe metal is scraped. This is OK. My own trials indicate that anodised ally will not work properly unless the anodising is scraped off.
To give you an idea how strong the bond is between two oilfree aluminium surfaces (rough the mating surfaces a little) is that in order to take it apart cold after it has set, you will literally tear the metal.
The only way it comes apart is to heat the glued job on a red-hot stoveplate and tear it apart after about 2 minutes, just before the aluminium melts.
I buy the stuff in a box containing 2 x 25ml tubes.
Regards all
bulgin
What glue to use feverdog873 Multi-Way 17 5th January 2009 11:46 PM
What glue to use? wixy Multi-Way 26 6th February 2007 11:49 AM
Glue like (better than ) RTV........ ashok Everything Else 8 5th June 2004 12:40 PM
Anodized Aluminum and Glue/Epoxy Bryan Tubes / Valves 22 18th May 2004 11:24 PM
Copyright ©1999-2013 diyAudio
