| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I have been browsing these forums for some time, following projects, seeing different designs etc.
So I thought it was time I jumped in on the action and created a project of my own, by all means I don't know much about the DIY audio business but I am willing to learn and want to get stuck in. I am looking to make a portable speaker with a 3" driver, I have been looking at the Monacor SPH-30X/8. Things I am unsure about: - Mono amplifier in order to power this driver (as most of the amplifiers I have seen only offer 2 channel, the only mono amplifiers kits I have seen are like 7W or less) - How small the enclosure can be in order to still create a generous sound - What rechargeable battery is recommended to power such a driver for say 10 hours+ All help will be appreciated. Thanks in advanced. |
#2 |
Tough one to answer and I'm no expert on speaker design.
Small (and how small is small ) sealed enclosure usually means low bass output.(I once had a small pair of rear satellite speakers intended for a car parcel shelf... probably was a 3" driver and the box was sealed and only around 4" square. Those speakers on the end of a 150 watt Pioneer A80 amplifier sounded amazing for what they were but they needed plenty of clean power). A battery puts limits on things. 12Volt ? SLA type (small sealed lead acid). The voltage puts a limit on the power available into a given load. You can't get more than a couple of watts RMS into a typical speaker from that. A "bridged" amplifier increases that by 4 times (in theory), in practice probably less. Some very knowledgable folk over on the single speaker forum, Full Range - diyAudio so perhaps a new thread there might help on the speaker design aspect. With a battery you need to make the most of evey volt so efficiency counts. I suspect an audio amp (probably a suitable chip amp) intended for car use might be the best bet for amplification. I'm assuming 12 volts though as you didn't say. For music a small SLA battery would easily last 10 hours on a charge.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
| Need a 4" Coaxial speaker for Portable Boombox | bnhoang228 | Car Audio | 22 | 25th November 2011 10:28 PM |
| Small 2 way "in desk" speaker build suggestions | Ceri | Multi-Way | 19 | 31st August 2011 12:14 AM |
| Portable Speaker System "Zen Visionary" with Sonic T Amp | Xspunge | Class D | 7 | 14th October 2006 08:25 PM |
| Mounting small speaker in 3/4" baffle | Dave Jones | Multi-Way | 6 | 21st August 2004 01:14 PM |
