Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 20th October 2003, 09:42 PM   #1
Question DIY Interconnects
General questions about the signal and return wires.
It seems that using the smallest gauge wire possible (that will handle the load being sent through it for the signal lead will decrease skin effect and increase all other positive attributes (attack time, harmonics, clarity, etc).
What about the return wire. Can this be a larger gauge or even a larger gauge in copper (if silver was used for the signal).
This is probably a silly analogy, but like the water plumbing in a house the return flow out of the house should have a higher capacity than the flow into the house, or there could be a backup.
Does this make sense or as usual is there something here I don't know or understand.
Thanks,
Ralph
Probably a silly question, but ........
Old 20th October 2003, 10:50 PM   #2
Signals are AC, not DC, so the current changes direction all
the time. To use your water-pipe analogy, if the flow of water
would change direction every now and when, it wouldn't make
sense to have different size pipes. That is, it wouldn't make
much sense to have different size conductors. However, this
is audio, and this thread is likely to get a couple of hundred
posts over the next few days claiming various strange
pehnomenae like cables being directional etc.
Old 20th October 2003, 11:02 PM   #3
I have been experimenting and looking at different designs for a few months now.
I agree that it does not make a differences. Kimber I believe uses a braid with 3 wires. 2 are for the return. I tried this using silver with no much success. It did help in knowing that the dielectric material held up doing such a braiding.
It's been said that using Silver with COpper produces gran,but I had success using such a design in stright form.
Try a few things to hear weather there is a maret improvement or which might work with what you are using is the beat advice.
I stayed with the same ga. in a cost effective straight design.
Experiment!
Interconnects planarboy Everything Else 0 30th June 2008 01:01 PM
Best Interconnects? Eric_B_C Everything Else 7 2nd January 2007 04:39 AM
DIY Interconnects RyanW Solid State 13 18th December 2006 11:58 AM
help please with interconnects! shepperd Parts 11 13th November 2006 06:09 PM
Cat 5 interconnects ddatta Everything Else 6 19th March 2001 02:42 PM
Page generated in 0.06888 seconds (84.01% PHP - 15.99% MySQL) with 10 queries
